rear seats of maxima
Old Mar 28, 2002 | 07:13 PM
dynamicmax's Avatar
how do you take off the rear seats of a 96 maxima so i can take off the shock/strut assembly..???
Old Mar 28, 2002 | 07:43 PM
Conrad283's Avatar
I need a truck
Re: rear seats of maxima
there are two rings to take off the "seat" part ... these rings are located below the seats, in the little crack ... once you find the rings you pull them .. then you take the "seat" part out ... then there are 4 10mm bolts that must be removed to take of the "back" of the seat .... they are located towards the doors, at the base of the "backing" you'll see them, they're on little thingy's (can't really explain it) ... the other two are located in the passage way to the trunk ... put down the arm rest and then the plastic piece so you can see into the trunk, and then there is another thing (it'll prevent anything from falling down there if the plastic piece is down) ... unscrew those 2 bolts and then lift the seat .. they're on 3 hindges ... and there you go
hope this helps
Old Mar 28, 2002 | 08:08 PM
j-95G's Avatar
uh, you don't have to remove the rear seats to get the struts out. they come out from the trunk. the 3rd gen has to have the rear seat removed, but not the 4th gen.
Old Mar 28, 2002 | 08:14 PM
MaximaPower's Avatar
aren't the struts under the carpet in the trunk?
Old Mar 28, 2002 | 08:41 PM
BRIGBOY's Avatar
Yepppppppppers...
Day Show Or!!!!!
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
