Side posts on Optima?
Old Nov 23, 2000 | 09:45 AM
Gotrice4's Avatar
How would i take advantage of using my side posts on my optima? what posts do i use and where do i pick them up? sizes and specifics are appreciated. i've been wanting to hook stuff up to the side posts but never really knew how. thanks.
Old Nov 23, 2000 | 11:41 AM
ereet's Avatar
Side posts?
You mean the extra terminals at the sides? If so, they're just there to give you an extra place to put your battery cables to allow you to fit the large battery in a space consuming slot. I'd assume you just hook up anything battery-related to them the same way you'd hook them up to the top terminals. If I'm wrong, what the heck are they suppose to do =) My optima ain't coming around till next week.
Old Nov 23, 2000 | 11:57 AM
emax02's Avatar
That is correct ereet,
I had know qlue what he was asking but know it makes sense haha.
Old Nov 23, 2000 | 01:56 PM
ericdwong's Avatar
In this pic, it isnt clear but I have a 175 amp Maxi fuse attached to the side terminal. From there, the 2 gauge wire goes into my fender, down the side of the car, and into my trunk feeding my amps. go down to the auto parts store, and buy side terminal mounts. Then, get the connectors that crimp onto the wire.
<img src="http://www.geocities.com/ericdwong/engine.JPG">
Old Nov 24, 2000 | 08:05 AM
Daniel B. Martin's Avatar
Re: Side posts?
Originally posted by ereet
.... ...If I'm wrong, what the heck are they suppose to do =)
Some makes of car use side terminal battery connections rather than the familiar top-side posts. The Optima battery provides both types of connection so they can cover a wide range of vehicle applications with just a few models of battery.
Old Nov 24, 2000 | 05:25 PM
Custommaxima.com
use it for your stereo
it is perfect for hooking up an amp to that so you don't need to mess with the factory hook up when connecting and disconnecting your amp.
boomerbrian
Sep 2, 2015 03:46 PM
umnitza
Sep 1, 2015 01:03 PM
Flores94
Aug 11, 2015 12:53 PM
dauntlessmax
Aug 5, 2015 10:29 AM
