Change Dome Light
Old Apr 2, 2002 | 07:49 AM
CatchnDolphn's Avatar
Change Dome Light
How do i change the dome light?
Old Apr 2, 2002 | 07:54 AM
mzmtg's Avatar
Minister of Silly Walks
Pry the cover off, pop the bulb out...
Old Apr 2, 2002 | 08:01 AM
HondaKiller718's Avatar
How to change dome light bulb
First and foremost, make sure your light and car are off. Electricity hurts.
Use a flat knife with paper lightly wrapped around the edge to prevent scratching. Stick the paper wrapped edge into the short side of the dome light facing the front of the car pop out the plastic cover. Once off, you can pop out the bulb, use a napkin or something to prevent the bulb from burning you if hot. Now, use a napkin again to place the new bulb in there. Your using a napkin to avoid placing any of your bodily oils on the bulb because that will shorten the life of the bulb. If you have already touched the bulb then clean it off with window cleaner or something of the sort. Once it back in, place the cover back on and walla- you've replaced you dome light bulb.
Now go ahead and test it..
carguy96
20
Feb 6, 2021 06:21 AM
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
RealityCheck
Aug 5, 2015 06:18 AM
