SE Tires on GXE/Speedo Conversion?
Old Apr 5, 2002 | 03:20 AM
cgfcgf's Avatar
Can you swap the stock GXE tires with SE tires and still have your speedometer/odometer still reading true? I'm not sure if the diameters are the same. I think a diameter change affects the speedo.
cgfcgf
Old Apr 5, 2002 | 03:38 AM
Kashoggio's Avatar
Re: SE Tires on GXE/Speedo Conversion?
cgfcgf
yup
dont really worry about it that much. I have 214/45/17s on and its only 3 mph off
Old Apr 5, 2002 | 06:22 AM
ftb87's Avatar
I also have that same question. Could you switch out the GLE for the SE rims and wheels. Is their a calabration for it or do you have to go to the dealer and have them program the computer?
One more...does any one have a set of SE wheels for sale?
Frank
Old Apr 5, 2002 | 09:38 AM
Kashoggio's Avatar
Originally posted by ftb87
I also have that same question. Could you switch out the GLE for the SE rims and wheels. Is their a calabration for it or do you have to go to the dealer and have them program the computer?try the for sale forum, or ebay has them always on. But if you are going to shell out that kind of money you might as well get some after market rims.
Try
www.tirerack.com
www.wheelmax.com
www.discounttire.com
Frank
Old Apr 5, 2002 | 12:13 PM
peteymax99's Avatar
Originally posted by Kashoggio
Check parts for sale 95maxima GLE has them or ebay. 215/55/16 is the tire to keep speedo normal. Same revs per minute as 205/65/15
Old Apr 5, 2002 | 01:24 PM
TooMAX's Avatar
cgfcgf
Yes, the speedo is affected, and generally a 2% difference is considered tolerable. Many trucks run 5-10% bigger than stock.
There's a tire/wheel calculator here:
http://www.powerdog.com/tiresize.cgi You enter the base 'stock' tire size and it lets you compare to other sizes and how much bigger or smaller they are from stock.
Old Apr 5, 2002 | 01:40 PM
peteymax99's Avatar
Re: Re: SE Tires on GXE/Speedo Conversion?
Specification Sidewall Radius Diameter Circumference Revolutions Difference
215/55-16 4.7 in 12.7 in 25.3 in 79.5 in 797 / mile 0.0%
205/65-15 5.2 in 12.7 in 25.5 in 80.1 in 791 / mile 0.7%
Old Apr 5, 2002 | 05:28 PM
nixima's Avatar
Do the math. If you swap your GXE wheels (assuming it's 205/65/15) with SE wheels (215/55/16), the diameter changes from 25.49" to 25.31". When your speedometer shows 60mph, you are actually at 59.6mph. When your speedometer shows 100mph, you are actually at 99.3mph. Will that be such a big deal to you? Even if you keep your stock wheels, the speedometer is usually off by a little anyways.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Calabar
Oct 5, 2015 09:57 PM
Garrettz459
Sep 28, 2015 02:50 PM
