Is there a reason why the Brake Indicator Light will not go out?
Old Apr 6, 2002 | 05:08 PM
deezo's Avatar
The E-Brake is working fine. What am I not seeing?
Old Apr 6, 2002 | 05:13 PM
MadMax55's Avatar
Check Brake Fluid
That happened to me and the problem was I was low on brake fluid. In the manual it tells you some of the problems it could be. Hopefully this is it. Good luck
Old Apr 6, 2002 | 06:00 PM
deezo's Avatar
Re: Check Brake Fluid
I'll check it out, thanks.
Old Apr 6, 2002 | 06:34 PM
maximaracer28's Avatar
Yea I had the same prob today, but put some more brake fluid in and all is good...
Old Apr 6, 2002 | 07:53 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Most likely the brake fluid , but also in spect to make sure your rear brakes are not dragging.
the cable may be binding or stuck, thus keeping the light on
Old Apr 6, 2002 | 08:01 PM
d_98SE's Avatar
Before you add any brake fluid into your car,check that your rear brake pad's are still there.
As the pad wear's, the brake assembly thingy move's in with the pad which then causes your brake fluid level to go down which then causes the brake indicator to go on.
Old Apr 7, 2002 | 12:30 AM
j-95G's Avatar
...or you might check your clearance on your parking break switch. just a thought...
Old Apr 7, 2002 | 06:17 AM
redmaxpa007's Avatar
i SeE what you did therE
take the light out of the indicator...
presto!!! no more light!!
Old Apr 7, 2002 | 06:28 AM
A few cans of spray paint and no more crimson blaze !
Old Apr 7, 2002 | 07:26 AM
deezo's Avatar
Old Apr 7, 2002 | 07:42 AM
deezo's Avatar
Thanks for the replies fellas. The brake fluid is low.
Old Apr 7, 2002 | 07:59 AM
my suggestion would have worked...
it was just not a good idea..
Old Apr 7, 2002 | 08:36 AM
I still think my idea was good, paint it something nicer...like sherwood green
Old Apr 7, 2002 | 08:38 AM
no asked for your idea or your opinion..
tsi6001
Oct 3, 2022 10:23 PM
trasmadean
Jan 20, 2018 05:05 AM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Samedi
Aug 13, 2015 04:05 PM
