short throw shifter
Old Apr 8, 2002 | 01:08 PM
blackmxma's Avatar
short throw shifter
just bought the pacesetter short throw and installed it. I reattached the heat shield underneath and just tried shifting through the gears, but I made the throw short enough that the control arm is rubbing on the sield. I know the directions say to cut a hole in it if its rubbing so I did, but the whole control arm is rubbing the length of the heat shield, so I cant make a hole in it that big. How important is the heat shield? can I just leave it off?
Old Apr 8, 2002 | 01:14 PM
SuDZ's Avatar
Another one solved by that mysterious search feature. Try it somtimes it is fun.
http://forums.maxima.org/showthread....shield+removed
SuDZ
Old Apr 8, 2002 | 02:59 PM
blackmxma's Avatar
SuDZ
yeah, I searched for short throw shifter, and turned up no results saying anything about the heatshield. When I searched for heatshield about 40 times the server was buisy, pobably cuz you guys spend you whole lives on here. so I just decided to post. did it really hurt you so bad?
Old Apr 8, 2002 | 03:10 PM
SuDZ's Avatar
So I help you then you get upset by it? I dont understand why. If the server is slowed down then like it says try again later. It is busy for me as well but I kept at it for you. Next time though, maybe not.
SuDZ
Old Apr 8, 2002 | 03:16 PM
blackmxma's Avatar
all I'm sayin is that I did use the "mysterious search function". In fact, I use it all the time. thanks for your help though...
Old Apr 8, 2002 | 04:40 PM
bidnizman's Avatar
Where did you get your Pacesetter? And yes, I have "searched" and gone to all the webpages listed in the forums, no go.
Old Apr 8, 2002 | 07:05 PM
JeffesonM's Avatar
living out of a maxima...
maybe some of us know about another "mysterious search"?
http://forums.maxima.org/showthread....ght=pacesetter
Old Apr 8, 2002 | 10:36 PM
jcy98maxse's Avatar
Turbo is too much fun!
Does it do that on every shifter?? I just order one but haven't got it installed yet.
Old Apr 9, 2002 | 03:46 AM
Mishmosh's Avatar
If the throw is short enough, then it will hit the heat shield and sound like your shifting a tin can POS. Leave it off or cut a hole in it. I, like others, elected to leave it off and have no problems.
Old Apr 9, 2002 | 04:01 AM
JPMontoya's Avatar
SuDZ
OH NO, not the search option post again!!!!
KRUSSSSSSSSSSSSSSSSSSSSSS..........EJECT,EJECT!!!! !!!!
Old Apr 9, 2002 | 04:19 AM
amb4081's Avatar
Re: short throw shifter
I tried cutting a hole in mine last week and it was still making noise so yesterday I decided to remove the whole shield. Others have done it and are having no trouble. I'm going to give a go too.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 31, 2015 02:04 AM
atriuum
Sep 28, 2015 01:19 PM
