If you have a service manual please help
Old Apr 10, 2002 | 11:14 AM
skeelo34's Avatar
I need help wiring my reverse lights on my 96 maxima. I did a 5spd swap. I believe there are wires that I have to connect to get my reverse lights to work, since most of the plugs on the tranny no longer fit (they were meant for auto). Could someone look these up for me? The haynes manual is too confusing, and no coloring on the wiring. Thanks!
Old Apr 10, 2002 | 04:15 PM
zboy's Avatar
There should be a plug with 4 pins on it connected to the transmission...comes out of the side that doesn't bolt to the engine. It's connected to the position switch. When you're in reverse, there should be continuity between pins 2 and 4, and when you're in neutral, between 1 and 3. Should be a green/white wire (pin 3) coming out of the connector that goes to the back-up lamps. I'll try to give you a little ascii diagram of the plug..
/1|2\
\3|4/
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
