brake torque specs
Old Apr 18, 2002 | 06:39 PM
blee89xj's Avatar
brake torque specs
I'm currently working on my front brakes. Am i right in assuming i have to remove the hub nut to take the rotors off right? Also, can anyone tell me the torque specs for the hub, brake pad bracket, and caliper bolts? thanks in advance.
Old Apr 18, 2002 | 06:53 PM
exhip95's Avatar
Re: brake torque specs
You do not have to remove the hub to replace the rotor (thank god)because it slides over the studs and is held in place by the lugs when you install the wheel.
Hub nut --------------------------174 - 231 ft-lbs
Caliper bracket bolts -------------53 - 71 ft-lbs
Caliper bolts----------------------16 - 23 ft-lbs
Old Apr 18, 2002 | 08:04 PM
blee89xj's Avatar
Okay, i removed the wheel, took off the caliper, took off the brake pad bracket. And from what you said, i should be able to take it off right? I must be missing a step or two somewhere since the rotor doesn't want to come off. Any advice? Also, thanks for the specs.
Old Apr 18, 2002 | 08:15 PM
blee89xj's Avatar
I don't know if this helps but i don't have abs.
Old Apr 18, 2002 | 09:02 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
The backside of the rotor hat is rusted to the hub. There are threaded holes on the rotor hat. You need to thread a screw (don't know thread/pitch on top of my head) into the hole(s) which will push out the rotor.
The other alternative is to use a rubber hammer, wrap the head in a thick cloth/towel, and gently tap the back rotor face every 1/4 turn.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
