Alignment HELP after H&R install....
Old Apr 19, 2002 | 07:35 AM
rmb's Avatar
rmb
So I just did the H&R + AGX setup on a 98 SE 5spd...
Install went well, I used pvc tube up front for noise and nothing extra on the rear springs. I used a floor jack to raise each front suspension corner a bit(lifted at the hub on the brake rotor) before I tightened the strut mounting bolts.
So I went to get an alignment after driving it around for a hundred miles or so and letting it sit for a couple days to let the springs settle.
Left Camber is -1.5 and Right is -.7 (which is out of spec on the left - should be -1.0 to .5)
Caster is 2.8/2.8
Toe is .10/.10 (was way off before they fixed it)
I told the alignment guy about futzing with the strut bolts to get the camber within spec but he didn't want to do it since only toe is supposed to be adjustable. There also seemed to be no way in hell to get 140 foot pounds of torque to those strut bolts without pulling off the wheels which won't work on the alignment rack.(A killer nice Hunter unit I really need in my garage)
I pulls a wee bit to the right, but it did before too. So what to do? Is it worth worrying about and trying to do something to fix it myself or do others here have the same sort of specs?
-RMB
Old Apr 19, 2002 | 09:15 AM
BRIGBOY's Avatar
Umm
Your reading too much into it. You torque the bolts to spec, then go get an alignement. The front camber of the maxima is naturally toe-out or positive If I am saying it right. Its definately not as square as the rear wheel will appear in contact with the ground.
And yes the Haynes Manual states that toe is the only adjustable aspect of our vehicles.
Old Apr 19, 2002 | 09:58 AM
Kevin Wong's Avatar
My alignment was perfect after I installed my H&R's and Tokicos. I just switched to AGX's a month ago and my camber is now off. The toe was completely off, but they corrected that and that's all I'm really concerned with. Incorrect toe will wear your tires much faster than an incorrect camber...unless it's extreme i.e. 3 degrees. My passanger side is within spec for camber, but the driver's side is -1.1 degrees...just .1 degrees out of spec. When I drive on the freeway, the car pulls straight so I figure its fine.
NewMax03
Oct 7, 2015 08:27 AM
06maxima55
Sep 28, 2015 04:29 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
ivorton23
Sep 26, 2015 09:47 AM
