Rewiring Corners.........
Old Apr 20, 2002 | 03:46 PM
kwamdoo74's Avatar
Carpe Diem....
I'm sick at looking at how dim my corner lights are, especially after buying these PIAA's.They look exactly the same as the stock ones. Has anyone experienced any problems once they've rewired their corner lights....? Do the bulbs blow out quicker or will my wires get fried?
Old Apr 20, 2002 | 04:55 PM
QuEeNz MaX KiD's Avatar
You dont have to rewire your corner lights to make them brighter. There's a much easier way.. all you have to do is solder the 2 connections on the bottom of the bulb together.. this will give you the same results as rewiring the connections but ALOTTTTTT faster and easier. The fuse might blow after you do this.. its a 7.5, replace it with a 10.
Old Apr 20, 2002 | 05:11 PM
elcid's Avatar
That's exactly what I did except I used a piece of tin foil cause I couldn't solder them because it's not metal. Works fine for me, I got the same light intensity all around.
Old Apr 20, 2002 | 05:21 PM
kwamdoo74's Avatar
Carpe Diem....
How long has it been since you guys made the adjustment, have you run across any problems with the wiring....?
Thanks for the feedback....!
97BlackMax's Avatar
wouldn't it be even easier if he just shaved the top nub off and then put the bulb in backwards?...that worked for me...clearance lights bright the whole time
Old Apr 20, 2002 | 06:20 PM
I had mine in for about 3 weeks now with no problems(except the blown fuse at first)... you shouldnt have any problems with the wiring..
HoLLa
Old Apr 20, 2002 | 10:07 PM
krzymax's Avatar
Maxima owner since 2000
works perfectly fine for me as well.
Old Apr 21, 2002 | 01:03 AM
Nismo's Avatar
I had it for about a month with no problems yet. Im running polarg bulbs.
Sir Tilus
Mar 22, 2016 01:49 PM
Blackwind
Aug 5, 2015 06:35 PM
MacGyver
Jan 10, 2001 05:12 PM
Cumalot
Dec 23, 2000 10:50 PM
perlmax90
Nov 13, 2000 06:10 PM
