Vacuum relief valve - HELP!
Old Apr 23, 2002 | 05:11 AM
maximachad's Avatar
Lifetime Maxer
Has anyone ever had to replace this valve?? The dealer wants like $200, and I want to see if I can do it myself...
-Chad
Old Apr 23, 2002 | 10:12 AM
maximachad's Avatar
Lifetime Maxer
Re: Vacuum relief valve - HELP!
-Chad
Anyone!!?? This valve apparently is located on/near the gas tank and releases excess pressure in the gas tank when the ECU tells it to...
-Chad
Old Apr 23, 2002 | 10:37 AM
mtman74
Re: Re: Vacuum relief valve - HELP!
-Chad
I haven't heard of it. Why does the stealer tell you it needs to be replaced? What symptoms is the supposedly bad valve causing?
Old Apr 23, 2002 | 11:12 AM
njmaxseltd's Avatar
I think he's refering to the purge valve. It sticks and throws the CEL light, I can't remember the exact codes it throws but it's a weird one because it points to many different areas of the evap system. Some guys on here have actually fixed that valve by taking it apart and lubbing it up. WD-40 works wonders.
BTW - That valve is located behind the left rear wheel.
Old Apr 23, 2002 | 01:34 PM
maximachad's Avatar
Lifetime Maxer
Supposedly, the ECU is sending an "OPEN" signal to the valve to release some of the pressure in the gas tank, but it's not opening. When the pressure doesn't go down, the CEL goes on. NJMAX - Can you explain to me what it looks like/what I need to do to lube it up?? Any help would be appreciated!
-Chad
Old Apr 23, 2002 | 02:02 PM
njmaxseltd's Avatar
Sorry Chad, I've never had to do this myself. Take a look under your left rear wheel, you will see the canister and some plumbing. Follow the electrical connectors and I'm sure you'll find the valve it plugs into. Take it out, test it on a bench using 12vdc. It should click open and closed. I read a thread on here a while back where a member took the valve out and was able to get it working again by cleaning it up with WD-40. Do a search on "Purge Valve" and see what you come up with.
On another note, My buddy has an I30 that used to throw the evap code every few days. We figured it was the valve as well. We cleaned the throttle body one day and the evap code went away. There is a vacuume orifice (sp??) in there related to that purge valve. If that orifice is plugged with varnish and gum, it can't bleed the pressure off the evap system. It worked for him, you may try that route as well. Might save you some time and a few bucks.
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
tardrex
Sep 11, 2015 07:35 PM
