EVAP canister purge volume control valve
Old Apr 23, 2002 | 04:25 PM
SLC I30t's Avatar
Where is this so I can replace it or figure out whats wrong with it? I am getting a 1008 DTC. Someone please advise.
Old Apr 23, 2002 | 05:58 PM
DSimple1's Avatar
Re: EVAP canister purge volume control valve
Louie..
Its located near the TB up top the engine. there is a round plastic UFO looking thing sitting on a bracket with a small hose coming out the top and 2 big hoses off the bottom. Thats the EVAP canister purge colume control valve.
Old Oct 14, 2002 | 01:09 PM
maxima168's Avatar
i got the same code and i took it out. but was wondering how do i open it up or the part number or how much it cost.
Old Oct 14, 2002 | 08:42 PM
SLC I30t's Avatar
Re: Re: EVAP canister purge volume control valve
Originally posted by DSimple1
Louie..
That post was over 6 months old. It turned out to be a a loose connection on the wire harness.
Old Oct 14, 2002 | 08:52 PM
maxima168's Avatar
lol. ok when i do search i get yeid at and when i dont search i get yeid at . i didnt see any harness connect to the canister.
Old Oct 15, 2002 | 07:18 AM
maxima4me's Avatar
I'm having the same problem....and no wiring harness. I Took it off (the UFO shaped thing), blew into it, didn't get a whole lot of resistance before it opened, sprayed some WD-40, put it back on, and same code.
I'm stuck....if anyone knows, let us know!
Old Oct 15, 2002 | 07:40 AM
JAIMECBR900's Avatar
Check all the vaccumm hoses to be sure they are connected properly and are not cut up. On most max's the EVAP solenoid is operated with vaccum.
Old Oct 15, 2002 | 10:19 AM
matty's Avatar
Whats the valve in the back of the car hooked up to the black box ?? I was getting a code from some evap code that my macanic told me and I ordered a valve for that black box thats getting stuck ?? 96 SE
-Matt
Old Oct 15, 2002 | 04:04 PM
SLC I30t's Avatar
Its not the UFO shaped thing.. its a silver actuator behind it and below it. My car has a tan/orange colored connection there. in that area. Thats the wire connection!!!!
Old Oct 15, 2002 | 04:13 PM
maxima168's Avatar
can you takes some pics?
is it LIKE the brass can on the right side?
EVAP
than how come "maxima4me said it is the ufo thingy?
Old Oct 16, 2002 | 07:01 PM
SLC I30t's Avatar
http://www.max-performance.net/image...gine%20bay.jpg
That solenoid for the EVAP is just above where the "STILLEN" letters are on my FSTB. In that pic it just looks like a metalic....thing.
http://www.max-performance.net/image...%20pic%202.jpg
In this picture its just left of the STILLEN letters on the FSTB has a brown plastic connection on it.
http://www.max-performance.net/image...48_23_full.jpg
just above the STILLEN lettering almost out of the picture.
http://www.max-performance.net/image...48_13_full.jpg
Well you can't see it in this picture... But I was just thinking how nice my engine bay looks in the first picture as compared to the last.
Old Oct 16, 2002 | 08:03 PM
maxima168's Avatar
the links aren't working. do u mean the black can on the side of the wall?
Old Oct 16, 2002 | 08:09 PM
maxima168's Avatar
oh nevermind. i see it. i dont have that can thingy. is your car a cail spec or fed spec? that might be why. i have a cail spec.
Old Oct 16, 2002 | 08:10 PM
SLC I30t's Avatar
no. go look at the vin number under your hood. its like just in front of the 2nd to last digit. My links worked fine when I just checked them.
Old Oct 18, 2002 | 04:08 PM
FLO_BOY's Avatar
the links work...the pics are small
I think I know what it is...
FLO_BOY
Old Oct 18, 2002 | 04:26 PM
SLC I30t's Avatar
Sorry I didn't think you wanted to Down Load the 500kb picture.
Old Oct 18, 2002 | 07:07 PM
munji's Avatar
the thing connected to the black box(EVAP cannister), is the vent control valve
Old Oct 18, 2002 | 08:36 PM
SLC I30t's Avatar
Thanks... I think
If you have a Chiltons, there is a really good diagram on chapter 4 page 30. 4-30
It will show you the volume control valve and where the purge control valves are. You can see clearly where the harness fits in on the upper portion. This thing we are talking about is under the hood, not on the tank itself or anywhere near it.
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
msellas
Sep 23, 2015 09:16 PM
dcam0326
Sep 7, 2015 07:26 AM
