not going to school tomorrow if no one helps me with this :(
ok, i made a mistake and rolled my driver side window all the way down...and it could not go up...i always pulled it up before but now i can't. I want to open my door and roll it up or just take off the alarm module controlling the window. Can someone please give me a step by step instruction on how i can open my door panal, and push up the window so i can go to school tomorrow? i go to school in newark aka CARS FOR FREE VILLE and i don't want to take any chances u know? Any advice and instructions would be highly appreciated....thanks in advance...i'll be nearby
This is a little guide to help you remove the front door panels...i took it off cheston's how-2 section for installing speaker system
To replace the front speakers, the door panels MUST be removed to access them. Although it looks like the grill can be removed, it cannot, except from the inside of the panel. There are 3 screws that must be removed. Two on the bottom of the door panel and one in the handle cup, under a plastic button. Once they are removed, pop the lens of the door light with a small standard screwdriver, remove the two Phillips screws, and unplug the light fixture. The last piece that needs to be removed is the plastic trim piece on the door release handle. This can be tricky to remove if it has not been removed before, but by using a small standard screwdriver, it will pop off. Be cautious as you do this, and too much force will break it. Once that has been removed, it’s time to take off the panel. There are little plastic snaps that snap the panel to the door, and to release them, you can use a tool that Crutchfield sells for about $3 that is a large fork that is slipped around the snap, and you lift up. If you don’t have this tool, a standard screwdriver will do. Set the panel aside
that's about as much help as i can be...sorry
heres another way, tho it is most likely the same exact thing
https://maxima.org/shoptalk/sub_modi...t2/index.shtml
Re: not going to school tomorrow if no one helps me with this :(
Looking ahead, if you want to fix it yourself, this is a DIY job. the same thing happened to me - the window suddnely decided not to come up. If you can get the door panel off, then all you have to do is either replace the regulator (the metal rail thing that physically opens and closes the window) or change the power window motor. a lot of people told me it was the regulater but mine was fine. it turned out to be the motor. I got a new motor at O'reilly for $150 + core. cheaper than the dealer, and it works fine now. Just don't forget to duck tape the window glass to the door frame.
Cheers!
Cheers!
JoshG
Sep 5, 2015 10:10 PM
sdotcarter
Sep 2, 2015 09:53 PM
