blown lights again (tailight, side markers, aftermarket fogs, inside gauge face).HELP
All of a sudden my lights go out yesturday during the rain as i was driving. This has happened before(not not necessarily in rain)...so i checked fuses...my relay box#2 had a blown fuse(15a), so i changed it. Turned on lights, boom, something blown again...this time its the fuse block below steering wheel (TAIL L. fuse 7.5a) so i change it...turn lights on, same fuse, goes out, ---after a while i put in fuse of smaller amount 5a...nothing happened. So im stuck ... i checked all fuses and they're all fine.
I'm going to my local speed shop guy to take a look at it, cus i went to him before for these kinds of problems....but is there anything else i can do before i go to him to fix it?
-I hope its not the wire going from my switch to the fuse block!!!
thanks in advance.
thanks in advance.
Re: blown lights again (tailight, side markers, aftermarket fogs, inside gauge face).HELP
Are your bulbs pulling higher wattage than a stock bulb? If you have higher wattage bulbs in your ligths that could cause it
thanks in advance.
thanks in advance.
vingodine
45
May 21, 2016 12:46 PM
