Engine Check Light
Old Nov 27, 2000 | 05:19 PM
saitoman
Okay guys (and gals)... I need a bit if help here...
I was on a road trip a while back. Unfortunately Premium Unleaded was unavailable, and I had little choice but to fill my tank partially with 89 octane. It must of set of my knock sensor. I checked the unit and got the diagnostic code.
Also, my idle is inconsistent. Either is is above 1,100 or falls below 500 to the point of stall. I've checked the throttle cable and it seems fine.
The Engine check light shows the diagnostic code of 4 long and 3 quick and 3 long and 4 quick blinks (These indicate a knock sensor and throttle position problems)
If you have any tips to fix this before I end up going to a dealer, I'd appreciate it.
Old Nov 27, 2000 | 06:16 PM
Daniel B. Martin's Avatar
Originally posted by saitoman
... ... The Engine check light shows the diagnostic code of 4 long and 3 quick and 3 long and 4 quick blinks (These indicate a knock sensor and throttle position problems)
If you have any tips to fix this before I end up going to a dealer, I'd appreciate it. Thanks
At the risk of stating the obvious, I suggest you check your Knock Sensor and Throttle Position Sensor. This requires only a manual and a good multimeter. Refer to Haynes,
- page 6-15,16 for Knock Sensor
- page 6-8,9 for Throttle Position Sensor
Haynes says that you must remove the upper and lower intake manifold in order to replace the Knock Sensor. After looking at my engine, I think that's not necessary. If you have good dexterity and a 1/4-inch rachet wrench, I think you can get it out in two minutes.
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Viralkill
Aug 16, 2015 05:09 PM
Samedi
Aug 13, 2015 04:05 PM
