Cleaning engine bay.....
Old Apr 30, 2002 | 10:12 AM
NISMOPower's Avatar
I want to clean my engine soon....do i need to cover up anything???? so i just use simple green anywhere on any parts or what? I wet then apply simple green then rinse....how long should i leave it on for? Is it safe everywhere??? has anyone experienced problems after cleaning engine with hose or pressure washer??? What kind if any....?
thanks
Chris
Old Apr 30, 2002 | 10:21 AM
1MAX2NV's Avatar
Re: Cleaning engine bay.....
Cover up the alternator if you can, it will prolong the life of the alternator. Spray simple green at full strength everywhere. You can use a nice sturdy brush to clean the heavy soiled areas. Use a tooth brush for those hard to reach areas. Spray everything down with a fine mist of water until you get all the simple green and grimes off. Avoid spraying water at one spot for too long. Just use back and forth motion. Wipe it down with some towels and start the car with the hood open. Most of the leftover water will evaporate when the engine warms up.
thanks
Chris
Old Apr 30, 2002 | 10:43 AM
NISMOPower's Avatar
what should i use to cover the alternator? Do I completely wrap the whole alternator????
Chris
Old Apr 30, 2002 | 10:54 AM
Kanaka's Avatar
aluminum foil is fine...just make sure to take it off before you start the car.
Old Apr 30, 2002 | 11:01 AM
sinewave's Avatar
I wash my engine compartment every time I wash my car, and I don't cover anything. I don't use Simple Green; I never liked it; I don't think it cleans very well. Since my engine is not greasy, I just use the same car wash soap that I use for the body. I mix up a bucket full of suds and wash the engine and then the wheels, then I dump that out and mix another batch for the body.
If you really want it to look great, wash the engine and dry it, then spray everyting down with ArmorAll and wait an hour, then wash and dry it again. All of the rubber and plastic parts will look brand new.
Old Apr 30, 2002 | 11:04 AM
mb1's Avatar
mb1
is that Simple Green stuff safe enough to use in your driveway, or do I need to take my car to a washing bay?
Old Apr 30, 2002 | 11:29 AM
Kanaka's Avatar
That's why they call it simple GREEN. It is very environmentally friendly. I even saw a salesman who squirted some in his mouth. not full strength, but diluted to household strength. No joking, I'm serious. I think it is a good cleaner and very safe.
Old Apr 30, 2002 | 11:34 AM
Jeff92se's Avatar
I'm needing a caw
I find it easier to go to the local car wash DIY places. They usually have engine cleaner that you spray on, then GENTLY rinse off w/ the same hose. I don't use the high pressure trigger as it comes out of the nozzle in the right velocity anyway. Same for the rinse. The high pressure might get into the connections. As long as you don't go overboard, you're okay. I've washed my engine many times so far with no problems. If you have a cone intake, you should probably use a plastic bag and cover it and tie it down w/ a rubber band/string.
Old Apr 30, 2002 | 01:03 PM
sinewave's Avatar
If you do take it to a DYI car wash, wait for the engine to cool off.
cold water + hot aluminum = bad things
derekinthez
Nov 13, 2022 04:00 PM
6spd4dsc
Mar 4, 2016 05:19 PM
Maximan190
Dec 16, 2015 06:01 AM
fastcarny
Oct 6, 2015 10:42 AM
03VQMAX
Sep 5, 2015 03:47 PM
