PCV Valve
Old May 1, 2002 | 03:28 PM
MaximaVQ97's Avatar
PCV Valve
WHats The easyest way to change it? or is there a web-site i could refer 2?
thanks
Old May 1, 2002 | 03:29 PM
SuDZ's Avatar
Re: PCV Valve
thanks
Just undo the tubing and pop it out. Pliers might (probably) be needed to get it out of the hole. Then put the new one in and reattach the hoses.
SuDZ
Old May 1, 2002 | 03:30 PM
MaximaVQ97's Avatar
Re: Re: PCV Valve
ya i tried that but the hose is caked on there and it wont come off
Old May 1, 2002 | 03:31 PM
ftb87's Avatar
What I did was losen the bolt that holds the tubing that connects the rubber tube to the PCV valve.
Do this and you can do the job in 10 minuites.
Frank
Old May 1, 2002 | 05:19 PM
fdxsiboy's Avatar
My friend you should of done a search...
http://integra.vtec.net/geeser/megamax/60k_service.html
Old May 2, 2002 | 08:37 PM
MIXXMAX's Avatar
Re: PCV Valve
thanks
When I changed mine, it was also very hard to remove. But, I don't like wasting any more time than I have to when working on cars, so I just cut the old hose and installed a new one.
Old May 2, 2002 | 08:43 PM
DJLAX152's Avatar
Re: Re: PCV Valve
When I replaced mine there was a little rubber gromet inside the whole that the pcv valve sat in. My new one was all plastic and didn't have a gromet so I left it in but it doesn't seem to go in all the way ( doesn't fall out but lip isn't flush witth the metal on the engine is this ok?
Old May 2, 2002 | 08:53 PM
MIXXMAX's Avatar
Re: Re: Re: PCV Valve
I don't remember seeing any rubber grommet. I replaced the PCV valve with a genuine Nissan one. It didn't come with a grommet, but the valve did fit flush with the metal, as did with the old one. Maybe, when I change it again I'll lookout for it.
Old May 3, 2002 | 07:34 AM
FLO_BOY's Avatar
I had trouble changing mine too -- i would suggest cutting the hose and installing the new PCV with new hose...also, the PCV should sit FLUSH -- I used a screwdriver and hammer to gently TAP the PCV into place.
I think if the PCV wasn't flush, then the PCV's functionality may be hampered...
-FLO_BOY
Old May 3, 2002 | 10:33 AM
Cumalot's Avatar
I have a question for you guys. Did the car feel any different after changing the PCV valve? I already did the fuel filter, ATF flush, knock sensor, and spark plugs seem to still be in good condition. The PCV valve is the only thing I haven't done. I already ordered one, should come in next week. So, any difference? Thanks.
Old May 3, 2002 | 10:48 AM
rmb's Avatar
rmb
You won't feel any difference except what's in your head. Kinda like how the car feels faster after washing and waxing for 4 hours...
It will keep you engine happy though by venting all the blowby gases and not letting the bad fumes dilute and crud up your oil.
-RMB
Old May 3, 2002 | 11:05 AM
FLO_BOY's Avatar
Your idle might be smoother -- certainly, your fuel economy will improve! mine certainly did!
FLO_BOY
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 20, 2015 08:22 AM
tardrex
Sep 11, 2015 07:35 PM
