How do I test for vacuum leaks?
Old May 7, 2002 | 06:10 AM
FLO_BOY's Avatar
any suggestions?
my car stutters -- some drives OFTEN -- like this morning...
the RPMs will vary wildly, but, it didn't shut off (this morning).
OK, so, I've already taken the normal steps:
1) Clean Throttle Body
2) Replaced fuel filter
3) Replaced PCV
4) Replaced Engine Coolant Temp. Sensor
So, I'd like to check out my vacuum hoses...any suggestions?
Thanks!
FLO_BOY
Old May 7, 2002 | 07:55 AM
rmb's Avatar
rmb
Re: How do I test for vacuum leaks?
Originally posted by FLO_BOY
any suggestions?
3) Replaced PCV
Thanks!
FLO_BOY
Your TPS (throttle position sensor) is most likely toast. I had a similiar thing. Mine would rev way high like it had gone nuts.
Better auto stores sell a little vacuum thingy with a gauge that lets you pull a vacuum on the line and watch the bleed-down rate.
Are you getting the CEL?
-RMB
Old May 7, 2002 | 08:00 AM
FLO_BOY's Avatar
Re: Re: How do I test for vacuum leaks?
-RMB
I'm not getting the CEL...
How do I test the TPS?
Thanks man, I appreciate the help!
FLO_BOY
Old May 7, 2002 | 08:38 AM
rmb's Avatar
rmb
Re: Re: Re: How do I test for vacuum leaks?
FLO_BOY
Use this site to test the TPS:
http://www.vbxmaxima.8m.com/tps.html
Replacement is more like $250, not $70 like the article says. But shop around.
-RMB
Old May 7, 2002 | 09:22 AM
kvzeyde's Avatar
clean the IAC valve
The idle air control valve may be carboned up. I cleaned my throttle body and then had idle problems. . When I cleaned my IAC valve it was like night and day difference on the idle.
Do a search for a recent thread about "high idle". It has instructions.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
