Idle Air Control Valve -- where is it? (I've searched)
Old May 14, 2002 | 02:48 PM
FLO_BOY's Avatar
I figure I should clean the Idle Air Control Valve (IACV), but I don't know where it is!!!
Also, I know that it should be cleaned kind of like the TB, so, any additional advice on this would be great!!!
Any help would be appreciated!!!
Thank You .ORG!
FLO_BOY
Old May 14, 2002 | 03:00 PM
mzmtg's Avatar
Minister of Silly Walks
OK, after your MAF, there are two hoses that come off the sides of the intake duct. Follow the one on the firewall side. It will lead you to the IACV.
Old May 14, 2002 | 03:27 PM
petemo95se's Avatar
What symptoms does a dirty IACF exhibit? How often do you clean it?
Old May 14, 2002 | 03:38 PM
SLC I30t's Avatar
it isn't that little black screw?
Old May 14, 2002 | 05:56 PM
Max4U's Avatar
Yes it is,
I never heard of anyone cleaning there IACV it is to be replaced if faulty.
A faulty IACV will cause the car to idle at low RPM's which will cause the car to vibrate and also when the car is idling the RPM needle will go up and down.
I had to replace mines 2 months ago.
Old May 14, 2002 | 06:01 PM
SLC I30t's Avatar
my car idles very very low sometimes if its coming down from a high rev it will almost die.
Old May 16, 2002 | 02:30 PM
FLO_BOY's Avatar
Originally posted by Max4U
Yes it is,
OK, so obviously there are two skules of thought on this:
1) You can clean the IACV
2) You can't clean the IACV, you need to replace it.
L'il Help???
Thanks!
FLO_BOY
Old May 16, 2002 | 02:44 PM
FLO_BOY's Avatar
HOLY CRAP!!!!
i just called my local dealer and he said that the IACV is over $400!!!!!! WTF???? I asked him to double-check, and sure enough
it was what I needed...
SO, is he on crack? I thought it was a little valve...
FLO_BOY
Old May 16, 2002 | 04:54 PM
MIXXMAX's Avatar
Originally posted by FLO_BOY
HOLY CRAP!!!!
FLO_BOY
Yes, this is a fairly expensive sensor. I had mine replaced at 60,000 miles. Luckily, Nissan replaced mine under my extended warranty.
Old May 16, 2002 | 05:10 PM
Keven97SE
The Maxima service manual specifically lists the method for cleaning the IAC valve, so it is obviously something that can be done.
Do yourself a favor and buy a service manual. It is perfect for these sort of situations.
Old May 16, 2002 | 07:06 PM
CitrusSpeed's Avatar
when you get done please post a how-to so all of us can do it, i don't have a service manual
Old May 16, 2002 | 07:13 PM
posnorder's Avatar
repair manual
$18 at your local AUTO ZONE
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
