Splash Guard Installation Question
Just purchased a 99 SE on Monday (back in the family again) and was looking to get a set of splash guards. Anyone put these on before? Just curious if I'm going to need to drill, or is this more of a 'snap-on' type? Read a few older posts about painting and such, but didn't see any mention of the installation. Thanks.
Yes, plug and play. Just need to remove the small trim pieces that are on there, and having a very small, stubby philips head would help a lot. Getting in there with the tire in the way can be a pain with a regular screwdriver. Turn the front wheels to get them out of the way, for the back use the stubby one.
i used a small screwdriver for the front ones...for the back ones, you are supposed to take off the wheels, which i guess is a fairly good security feature, but i used a weird tool (dunno what it was called sorry). it was almost like a thicker alan wrench that fit just right and i was able to screw them in pretty much all the way. goodluck
Instead of removing the wheels try using a phillips head bit and an open end wrench. I'm referring to the type of screwdriver that comes with a set of interchangeable bits. Use the phillips head bit with an open end wrench to turn the screw.
BassAddictJ
Aug 4, 2015 11:38 AM
