Rear Heated O2 sensor
Old May 18, 2002 | 06:43 PM
sohailnz's Avatar
i did a self diagnostic on my 95 maxima gle and came up with an error code 0707 which is Rear Heated O2 sensor. What the hell is that and how do i fix it ! Plz help .... man .. my max .... is making me dish out a lot of mollas in the last couple of weeks .. first the mouse eating the coil and injector wires, then the shot brakes and now this ,,,,, and i thought max were far more reliable and durable than the hondas
Old May 18, 2002 | 09:05 PM
JAIMECBR900's Avatar
Re: Rear Heated O2 sensor
If you crawl under the car right between the driver and rear door, look at the cat, and you will see the rear O2 sensor right behind it going towards the back of the car. It is very simple to install. It's plug and play. As for reliability; If mice chew on honda wires, they'll cause problems too. Brakes are part of regular maintainance and once again I assure you Honda brakes go bad too.
Old May 19, 2002 | 11:45 AM
sohailnz's Avatar
thnx for the help ... now could you help me in finding the best deal to purchase this part and where should i go looking for it
Thanx
Sohail
Old May 19, 2002 | 11:48 AM
SLC I30t's Avatar
Thanx
Sohail
cahnces are you dont have to replace the part. Just clean the soot off of the sensor. use an alcohol wipe or put some alcohol on a rag and wipe it down real good. allow it to dry and put back into your car.
Old May 19, 2002 | 08:31 PM
BippuBenji's Avatar
If only I knew that I could do that before I spent $145 on a new one. It kind of worked out anyway when I couldn't remove the old one to put it in my Greddy so I had to get a new one since the bolt was stripped.
Old May 19, 2002 | 09:04 PM
Supermachoman's Avatar
I got code 0707 a couple of days ago. I reset my ecu and everything has been fine since. Chances are that it was just a brief problem, but enough to set off the MIL, reset the ecu and see if the MIL comes back on in the next 100 miles or so. If it does you probably need a new O2 sensor, if it doesn't you're home free.
Old May 19, 2002 | 11:30 PM
lefty
should you clean out your O2 sensors as described above regularly?
Old May 19, 2002 | 11:33 PM
SLC I30t's Avatar
I dont think its necessary, that is something I did to try and be thrifty. It worked when I did it, and when I pulled the O2 sensor last weekend when swapping out the exhaust it was still clean after 7k miles. I would suggest to anyone now to just clean the tip off before spending 100 bucks on a new one. Unless you bust the plastic clips where it attaches to the underside of your car.
Old May 20, 2002 | 10:01 AM
deezo's Avatar
Thanks for this info. I keep throwing the 0707 code.
Old May 20, 2002 | 10:34 AM
sohailnz's Avatar
thanx guys .. i keep throwing the code on a frequent basis ! like every month or something .. but i dont need to worry . just need to turn the ecu clock wise and counter clock wise twice and the check engine light vanishes .. its so easy !
Sohail
Huttig2009
Sep 25, 2015 03:31 PM
iflexsteel
Sep 15, 2015 03:37 AM
homeyclaus
Sep 3, 2015 06:15 PM
Maxilano
Aug 31, 2015 07:33 PM
