just got new rotors and pads .. but the scraping sound wont go away .
May 20, 2002 | 10:36 AM
i changed the rotors and the brake pads .. but the light scraping sound is still there .. and now it also whistles at low speed braking ...what could it be !
Sohail
May 20, 2002 | 11:07 AM
Check the dust shield, sometimes they get bent and rub up against the rotor.
May 20, 2002 | 12:50 PM
My car is doing this as well. However I'm giving them about 300 miles to break in and if they continue to do this then I will take it back to my mechanic. It' seems to have lightened up a little bit. The pads & rotors just have to seat into each other.
May 20, 2002 | 01:11 PM
I thought that it wasn't wise to change both the pads and the rotors together...I was under the impression that you should have changed the rotors first, leaving your old pads on them (if they are good), and then put the new pads on breaking both in gently. But like someone first said...check that brake dust cover, mine did it for a while, after I changed my axles but it has since stopped. Good luck
May 20, 2002 | 02:09 PM
thanx ~! I guess i will give it sometime for settling in .. i dont think it could be the dust cover though ... as the scrapping sound comes when i apply the brakes .. otherwise its ok
May 20, 2002 | 02:52 PM
There should be no scraping noise what-so-ever. Mine did the same thing. Only made the noise when I hit the brakes and it WAS the shield. Don't rule that out w/o looking at it first. Did you put anti-squeal on the back side of the brake pads, and did you install the bushings (or whatever they're called - retaining clips/springs)? Also, you described a whistle. Did you get cross drilled rotors? They will whistle sometimes. One last thing, watch your rotors. They should wear evenly. If you start developing ridges in them then something is wrong. Good luck.
May 20, 2002 | 04:31 PM
Quote:
Did you use Nissan pads or aftermarket. I never had a problem with the nissans.
May 20, 2002 | 11:11 PM
i have been told, that aftermarket pads are more harsh hense the louds sounds. the oem pads are softer organic compounds, although the will wear faster.
May 21, 2002 | 03:30 PM
after market pads and rotors .... $65 a pair each .. cross drilled and metallic pads .... how do you check the dust cover though ?
May 23, 2002 | 07:39 AM
Quote:
take off the wheel and look to see if it's touching the rotor.
May 23, 2002 | 08:52 AM
What's the best aftermarket pads out there (organic preferably). Also, if your brakes do squeal, what's the most common prob for it?? Thanks for ure help.
May 27, 2002 | 08:32 AM
if you want organic, stick with stock or the Axxis Deluxe.
