180 speaning ????
Old May 21, 2002 | 02:58 PM
myiqis180's Avatar
180 speaning ????
I was taking the entrance to a highway and 'slightly' steped on it just to test the car's stability, well the back of the car went on a complete completely around and the car started to spin. I have new tires on the front Bridgestone Potenza RE 950, but the one on the back I think are stock (80K miles) But when I looked at them they don't really seem bold, (border line at most). It happened today again at very low speed (but a another curve) Any ways, I just ordered tow more Bridgestone.
My question is: could there be any reason (other than needing new tires) why this happened. Plus, should I check anything other than the alignment to make sure nothing else got hurt by the spinning?
Thank you for your enlightment.
Old May 21, 2002 | 03:27 PM
gtr_rider's Avatar
192.168.1.1
Your car made a 180 on an entrance ramp!?!?
Old May 21, 2002 | 03:37 PM
myiqis180's Avatar
Yeah!, I was lucky that the car behind me saw me, and there weren't more than 3 cars around. I Just went back up the ramp (the wrong way) made a U turn and got back on the hight way. Both time I was lucky that there were no collitions.
Old May 21, 2002 | 08:26 PM
luckee2bhere's Avatar
I did that **** before in my old GS-R. I tapped the brakes cause I thought I was in too fast. Car went right around....didnt hit anything...lucky..slid less than a foot away from gaurdrail backwards for 100 ft.
lesson learned-> NEVER tap the brakes in the midst of a turn!
HA
Old May 21, 2002 | 11:48 PM
DiscoGsus's Avatar
Re: 180 speaning ????
If you have a RSB that might cause you to do that, or a very heavy box/**** in the trunk...but I doubt it. I can't even get the back of my max to step out on gravel corners w/out pulling the little handle next to my seat.
Nothing should be hurt by spinning your max if you didn't hit anything. As far as your car is concerned it just did a fast corner.
Other possibilities:
1. Your LSD got very confused (you probably don't have one)
2. Your front wheels are toed in too far, or back wheels are toed out
Just my $.02
Old May 22, 2002 | 10:01 AM
myiqis180's Avatar
Re: Re: 180 speaning ????
Just my $.02
What is RSB? LSD? (is that for the Canadian Edition?).
I am so bad with abreviations.
Old May 24, 2002 | 12:45 PM
RSB= Rear sway bar
dont know the other one
Old May 24, 2002 | 12:52 PM
97BlackMax's Avatar
LSD---I believe it is Limited Slip Differential...only on I30s and Canadian Maxes I think
Old May 24, 2002 | 01:17 PM
myiqis180's Avatar
Thanks guys, I learn something new every day.
My brain gets smarter.
My Max gets nicer.
My savings get smaller.
Old May 24, 2002 | 04:53 PM
densetsu's Avatar
i try to do 180s and it is difficult to pull them off in the max without using the e-brake, i wish it was as easy to do for me as it is for you.
Old May 24, 2002 | 05:19 PM
myiqis180's Avatar
Try going down hill, on a wet road
Old May 24, 2002 | 06:23 PM
Newman's Avatar
is it me or is 80k miles A LOT of miles for a tire? those things should be long gone.
Old May 24, 2002 | 08:46 PM
Yossarian's Avatar
what happened is you tapped the gas, and when you let off, a condition of oversteer was created (do you have a rear anti-sway bar?) and the rear end slid out
normally the rear end sliding out wouldn't be so extreme, but your front axle has a set of brand new performance tires while your rear has 80K mi on stock tires, so there is a huge difference in traction between front and rear
after recently installing my RSB my rear end was sliding out too easily in certain conditions (wet roads esp. in storms, gravel or sometimes sand on paved roads, etc.) so i decreased the rear tire pressure so that it was one pound/sq inch less pressurized than the front - this had the opposite effect of what your tire configuration did, making the rear more grippy
btw, i did a 180 on a freeway entrance ramp this past winter - that felt reeeaaal nice (adrenaline!) if you know what i mean, my car was moonwalking like michael jackson , it just went 180 and moonwalk/slid backwards into the snow piled up on the side of the freeway for a nice cushiony landing
Old May 28, 2002 | 09:43 AM
myiqis180's Avatar
> btw, i did a 180 on a freeway entrance ramp this past winter - that > felt reeeaaal nice (adrenaline!) if you know what i mean,
Yeahhh, I definitively know what you mean. The first time my heart was pounding like "wow". The second time it lost the effect , I was like "what ever".
I don't have a RSB, but shouldn't that prevent your car from doing speans, instead of making them eisier. The back of my does feel kind of loose, and wabaly when I hit 100mph and over. (Not that I dod that often )
Old May 28, 2002 | 10:57 AM
njmaxseltd's Avatar
At least somebody caught the problem.
Those tires have lost the ability to grip the road. Change them ASAP!
The rubber is probably all dry and probably has cracks along the sides as well.
You may also have weak shocks in the rear which will cause excessive sway and the rear end to break lose quicker then normal.
Can anybody tell me what "SPEANING" means? Is this a new Maxima.org word?
Old May 28, 2002 | 11:19 AM
myiqis180's Avatar
Yeah, I already go new tires, so I'll have them mounted next chance I get. maybe I'll check the shocks too.
BTW: "SPEANING" is a term that non-native speakers who can't spell (like me) use to refer to the "SPIN"
NmexMAX
Mar 1, 2016 08:35 AM
NmexMAX
Wheels/Tires
Feb 18, 2016 11:33 AM
Maxxx10
Sep 13, 2015 03:16 PM
tnewbs
Aug 28, 2015 10:15 AM
KGMtech
Aug 18, 2015 09:21 AM
