must buy weatherstip?
Old Nov 30, 2000 | 09:13 PM
riggy's Avatar
if my weatherstip around the trunk is leaking from somewhere which is what i was told, is there anyway i can fix it with tape or anything or is it not worth bothering with and just getting a new one????????? thanks.
Old Nov 30, 2000 | 09:39 PM
justmax's Avatar
hold on...
R U sure it's the trunk's weather strip? Check the strip all the way around, does it have rips, tears, or is it separating from the body anywhere? Most leaks come from the gasket between the tail light assy. and the body. I already had to replace a tail light and it's got a 1/4" thick strip of what I can only describe as a tar-like substance keeping water from coming in thru the holes in the body behind the tail lights.
So if you do find an actual verifiable leak in the strip around the trunk, buy a new one from the dealer, don't just jerry-rig it with tape.
Justin
Old Jul 25, 2002 | 02:02 AM
magic_max's Avatar
Re: hold on...
Did anyone ever get a quote for these weather strips from the dealer? It can be the trunk and/or door weather strips? I always wanted to know how much these run.
Thanks,
magic_max
'96SE
Justin
Old Jul 25, 2002 | 07:03 AM
blizz20oma's Avatar
I'm so hood
The trunk weatherstripping piece that goes all the way around is $62.00 from courtesy.
(Yea, that's for my 95, but I figured the 96 would be the same. Can't say the same about the 97-99s)
Old Jul 25, 2002 | 11:22 AM
magic_max's Avatar
Thanks for the reply. I'm assuming thats for your '95...I figure it should be in the ball park for my '96.
~magic_max
Old Jul 25, 2002 | 11:35 AM
vipervadim's Avatar
I like Maximas
check out www.jcwhitney.com and do a search for weatherstrip if you can't find it anywhere else.
-Vadim
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
