gauge face removal
Old May 24, 2002 | 03:53 PM
geo1317's Avatar
gauge face removal
do I need to remove the needles to be able to remote the gauge faces?
Old May 24, 2002 | 04:07 PM
XXXL Cracker's Avatar
On my '97 GLE I had to remove the needles...
I put white gauge faces in my gauge and I had to take off the needles and recalibrate them.
Not too hard after you do it once, the first time my needles were not working properly so I had to adjust them.
Hope that helps!
DL
Old May 24, 2002 | 04:13 PM
Hope that helps!
DL
Old May 24, 2002 | 06:10 PM
Gary95's Avatar
Re: On my '97 GLE I had to remove the needles...
How did you get the clear plastic cover off? I've found all of the tabs release, except for the upper left and right corners. They're stuck in tight. I don't want to break anything... how'd you get them out safely?
Old May 24, 2002 | 06:17 PM
geo1317's Avatar
Re: Re: On my '97 GLE I had to remove the needles...
its all tabs just make sure you get all of them, get them to release one at a time and when all of them have released, then pull the cover off.
Old May 24, 2002 | 06:20 PM
Newman's Avatar
Re: Re: Re: On my '97 GLE I had to remove the needles...
but be very careful. i broke mine while trying to take it off. its about $35 for a new one.
Old May 24, 2002 | 06:33 PM
Gary95's Avatar
Re: Re: Re: Re: On my '97 GLE I had to remove the needles...
I figured it out. You see the problem, is that the upper left and right corner tabs have NO ROOM to flex, unlike the others. They are flush against the white plastic housing. I discovered that if I undo the two BLACK tabs for the black gauge face cover that are next to them, I can move the tabs far enough forward to finally flex them. Then they slide out. I had to use two pry tools, one to hold the black cover out, the other to get the tabs down. It worked!
This was TOUGH TO DO. I'm surprised no one mentioned it in the process. "Just release the tabs and the plastic cover comes off" is what I've seen in all the postings about it. Oh yeah, right. Nope, it ain't that easy. At least the method I came up with worked like a charm and nothing broke. Maybe this is only particular to the 95-96 models?
my03maxima
Jul 28, 2024 07:40 AM
Miket2006
Mar 1, 2021 03:55 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
