Can someone help me with this code
Old May 27, 2002 | 07:25 PM
maxedout95's Avatar
i got this code out of the computer ECU 5 long 4 short
the result is
Automatic Transmission Control Unit Signal to ECU
i also got one for the knock sensor
Old May 27, 2002 | 07:56 PM
SLC I30t's Avatar
dont stress the Knock sensor yet. It tends to be a tattle tell of sensors. Once one goes off it goes off, its kind of the little ***** of the car. As far as your other one. lemme check
DTC 0504
Diagnostic Trouble Code 0504 points to a problem with the Automatic Transmission Communications line.
Pulse signals are exchanged between the Engine Control Module and the Transmission Control Module to assure
smooth shifting during hard acceleration or deceleration.
This malfunction is detected when the ECM continuously receives an incorrect voltage from the TCM.
Possible causes include...
- Harness or connectors (The communications line circuit between the ECM and the TCM is open or shorted.)
- TCM
- Discharged or faulty battery
Now I dont know what it all means, but it looks to be a automagical problem in you thingy.
Old May 27, 2002 | 10:44 PM
MIXXMAX's Avatar
Re: Can someone help me with this code
the result is
Your transmission triggered a fault in the transmission computer, sending the code to the ECU. This could be caused by hard acceleration or deceleration, or some type of problem(s) with shifting of the gears. You can clear your ECU and the codes should disappear. You can also extract any codes in the transmission computer to give you an exact code of what went faulty. The process is lengthy, but it is worthwhile just in case your curious. If you have access to a Hayne's manual, you can find the process explained on pages 7B-2 and 7B-3. Did your Overdrive lamp "flash" in any way?
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
