Besides wheel imbalance, what else could cause... >>
Old May 28, 2002 | 05:14 AM
Albertt's Avatar
...steering wheel shake?
I recently replaced my rims, had them mounted and balanced by Mavis Discount Tire, and I'm noticing vibration at my steering wheel. It seems to be the most prominent between 72 and 82 miles per hour. Any ideas on what else could be damaged and in need of replacement? Tie-rod ends? Suspension arm bushings?
AL
Old May 28, 2002 | 07:29 AM
seven's Avatar
Re: Besides wheel imbalance, what else could cause... >>
AL
do you have hubcentric centering rings?
Old May 28, 2002 | 07:54 AM
Albertt's Avatar
Seven, no I don't >>
The rims are the OE 16" five-spoke rims from the 4th Gen SEs. I don't think hubcentric rings are needed.
Old May 28, 2002 | 08:02 AM
ejj's Avatar
ejj
Sounds exactly like the problem I had on my 91 stanza when a ball joint went bad. I'd check them first.
Old May 28, 2002 | 09:03 AM
red112fl's Avatar
I had this exact problem (steering wheel shake at 70mph +) on my 95 SE with 109,000 miles. After I replaced the passenger side lower control arm assembly, it completely disappeared. I also lowered the car with B&G Springs at the same time, but this shouldn't have explained the fix. I did nothing to my tires at this time. Check out www.nissanparts.cc for a decent price on this part. Good luck.
Old May 28, 2002 | 09:10 AM
ejj's Avatar
ejj
The lower control arms have the ball joint intergrated into them. If you replaced the control arm, you replaced the ball joint as well.
MikeD95SE's Avatar
AL
GET AN ALLIGNMENT!
Old May 28, 2002 | 09:32 AM
Albertt's Avatar
ejj5875 & MikeD95SE >>
ejj5875: Is this ball joint the one that the upright joins to the lower control arm? Is there a bushing in this ball that goes bad? How do I know which side to change? Are there telltale signs that the ball joint has gone bad when I look under the car?
MikeD95SE: I just had the alignment done by the same place that mounted and balanced the tires. The car has had no problems tracking straight.
Old May 28, 2002 | 09:35 AM
ejj's Avatar
ejj
Re: ejj5875 & MikeD95SE >>
Yes, I think.
Other than that I can't help you. I found out that was the problem with my Stanza from a shop, before I knew a damn thing about cars.
I've never had problems with them on my Maxima(s).
Check out this thread: http://forums.maxima.org/showthread....ball+AND+joint
Old May 28, 2002 | 10:16 AM
peteymax99's Avatar
Re: Re: ejj5875 & MikeD95SE >>
Originally posted by ejj5875
Yes, I think.
First bring them back to get REBALANCED. That could be the problem.
Old Jun 3, 2002 | 06:18 AM
Albertt's Avatar
Reviving this post: I had the tires rebalanced and alignment done again >> >>
For free...Mavis was actually quite apologetic...they forgot to remove the old weights which were taped inside the rim and covered with duct tape.
So, the tires are balanced, car still tracks pefectly straight...but I've still got vibration. I did notice that the ride was smoother at slower speeds and the vibration comes on at around 70, but not as severly. Also, it seems as though the severity of the vibration varies...almost none when cold. I also realized that my brake rotors are warped...after only 8 months of service. Could severly warped rotors cause vibration at high speed?
Wouldn't worn bushing show vibration at any speed?
AL
Old Jun 3, 2002 | 07:31 AM
meccanoble's Avatar
Sports Button FTW
AL
my alignment was WAY off because of f*cked up tie rods and my wheel wasn't shaking, just wasn't steering straight...does that happen when u brake or just when u driving? if when u brake then i think u have bad rotors cause my friends toyota was shaking till he changed his rotors....if happening while driving...hmmm.....maybe your axles? could be bad alignment...normally alignment fixes everything anyway ...
Old Jun 3, 2002 | 08:17 AM
Albertt's Avatar
I don't think anything is bent, because the alignment/balance shop would've told me >
There is steering wheel vibration when I'm driving...but a different mode of vibration in the steering wheel AND brake pedal when I brake hard. I'm pretty sure my rotors are warped, I'm just questioning whether or not my non-braking vibration could be caused by the rotor warpage.
Old Jun 3, 2002 | 08:30 AM
got rice?'s Avatar
just to add - steering rack bushing
Old Jun 3, 2002 | 11:31 AM
peteymax99's Avatar
Re: I don't think anything is bent, because the alignment/balance shop would've told me >
Try having the rotors cut. That might slove the braking problem.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
