What Is A Good Way To Clean Engine??
Old Jun 3, 2002 | 02:52 PM
max_speed97's Avatar
i have never cleaned my engine and you know how it gets...all dirt and black and stuff....now while i was getting a new battery for my car i asked what is a good way to clean the engine? i was told with soap and water....just all over the engine...is this correct??? oh i have injen cai so what should i do?
second i also wanted to know how to keep the battery clean also...the + and - tips where the connector goes on and the guy also told me to just poor hot water over it. is this right????
all replys thanks
Old Jun 3, 2002 | 04:00 PM
RastaManMax's Avatar
Get a toothbrush, some degreaser to loosen all that rubbish already built up under there, (cover up the battery and various other wiring)... Then soap and water... Then water and you're done...
Old Jun 3, 2002 | 04:02 PM
JMAXIMA's Avatar
Re: What Is A Good Way To Clean Engine??
all replys thanks
hey man... i actually did this last week and its pretty easy. i had some concentrate Purple Power cleaner and i just diluted it about 1 part cleaner / 4 parts water. i covered my pop charger with some plastic and put a plastic bag over my battery. soaked the engine with the cleaner ... let it set for 3-4 min maybe.... sprayed it off... and there ya go... a nice, shiney engine. and if your engine is really dirty try making the solution stronger or you might have to get a rag or something. oh, and be sure that your engine is not hot... you might crack something. good luck
Old Jun 3, 2002 | 04:15 PM
seems pretty simple...thanks...one more thing, i guess i should cover the cai also?
Old Jun 3, 2002 | 08:29 PM
erty67's Avatar
Decal Specialist
Simple Green works good for me. Also, if you get corrosion on your battery terms...just get a can of Coke(not pepsi!) can pour it on the terms one at a time. You will be surprised how well Coke eats that corrosion away! other than that, just wipe down the battery with a old wet rag.
Old Jun 3, 2002 | 08:33 PM
BBaker025's Avatar
Get some simple green, go to a coin car wash, wash your car:time 4 engine to cool off, spray simple green all around and watch all the grease drip, spray the high pressure car wash wand over the engine, keep engine faced toward the sun for an hr. Perfectly clean engine
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
