Help with suspension checklist
I'm gonna be swapping out the Eibachs for H&R's and I wanted to compile a check list of stuff I should buy, just want to make sure I don't miss anything, do I need two of each of these? Is there a differnt partenumber for left vs right?
Strut Spacer 54329-39U00
Strut Bearing 54325-5V000
Strut Dust Cover (Boot) 54050-31U01
Rubber seat 54034-0W000
Polyurethane sleeve 54034-85E10 ( are these Isolation sleeves?)
Polyurethane endlink bushings ?????
- Rear -
Strut Spacer 56218-61L10
Dust Cover (Boot) 55240-01A00
Rubber Seat 55034-31U00
Polyurethane sleeve 55031-33P10
Cover Washer 55248-01U00
Isolation Bushing 56218-61L10
EDIT: stupid three word subject rule.
- Rear -
Re: Help with suspension checklist
It looks like you've got everything. There are different P/N for front and back, but not for left and right. you'll need 2 of each. the Polyurethane sleeve is the isolation sleeve - that's what people have been using spiral wrap for instead of the isolation sleeve.
I just noticed that the picture of your max doesn't have a license plate in the rear. how'd you manage that? Have you gotten pulled over by the cops? and where'd you get the clear spoiler light?
- Rear -
- Rear -
Kevin,
I just did my suspension (all 4 corners) and I still have the plastic bags where the parts used to be. I know one this is wrong, the Rubber Seat 54034-0W000...this is not the correct one!
If you could wait until tonight, I will post my part numbers and compare it to yours. I am positive that the rubber seat is the wrong one, since I ordered the same thing and it did not fit.
- Rear -
EDIT: stupid three word subject rule. [/B][/QUOTE]
- Rear -
Re: Re: Help with suspension checklist
Sure,
If you could post the part numbers that woudl be very helpful. thanks in advance!
Kevin
EDIT: Mango, the rear was done with photoshop! Guess I did a pretty good job with it.
[/B][/QUOTE]
Kevin
Originally posted by ardika
Kevin,
- Rear -
Kevin,
- Rear -
Kevin,
- Rear -
Kevin,
- Rear -
Your right! That number is wrong. The correct part number for the front seat is 54034-31U01.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
