Vibration in Shifter (5spd)
While driving I usually have my right hand on the shifter and my left hand on the wheel. I've noticed for quite some time that there is some vibration in the shifter while driving. The vibration becomes more pronounced if I push the shifter lightly to the opposite side of neutral. For example if I'm in 2nd or 4th and I push down on the shifter (away from neutral and towards e-brake) I can feel the vibration getting stronger. Same thing in 3rd (push away from neutral and towards stereo). Also sometimes I cant get into 1st or Reverse and I have to double clutch.
Do you guys have any idea what could be causing this. If so help me out.
Nas
Nas
Originally posted by nardo'89SE
normal, your shifter is connected to directly to the tranny which is connected directly to the engine, so your feeling the vibration off the engine
Anyone else have the same problem??
its possible that the 240sx had some kind of cable or indirect linkage to the tranny, i know my 3rd gen has a rod connection, pretty sure about the 4th gens having them too, a little vibration never hurt anything
Re: Vibration in Shifter (5spd)
Nas
Nas
Re: Re: Vibration in Shifter (5spd)
Originally posted by Smooth Operator
Do NOT rest your hand on the shifter! You will put load on the gear and cause wear to the shift forks, syncros, etc. Put your right hand on the steering wheel where it should be.
If you do keep your hand on the shifter, use a very light touch. Then when you're ready to shift, grab that thing and GO!
DW
DW
id say keep it there when your going 1 to 2 to 3, then take it off once your crusing in 3rd
ef9
Oct 4, 2015 08:43 AM
atriuum
Sep 28, 2015 01:19 PM
