OOH OOH me too!
Old Dec 4, 2000 | 04:27 PM
mzmtg's Avatar
Minister of Silly Walks
I just rewired my corner lights. Took me 10 minutes. Fun fun.
Old Dec 4, 2000 | 04:37 PM
SmoothMax's Avatar
OG
Rewired to stay bright all the time right? What do you think of the result man? Worth it or not?
Old Dec 4, 2000 | 06:35 PM
airmattdog's Avatar
Guy with the Orange Max
Questions
I'm interested in doing this also. How difficult was it to do? I got the directions off of http://www.maximadriver.org I guess I'm not extremely mechanically inclined. I also want to rewire the foglights too. Anyone in the Seattle area know how to do this?
Old Dec 4, 2000 | 06:49 PM
xHypex's Avatar
I rewired my corner lights a few weeks ago and I think it looks great. It really helps even out a superwhite bulb set If you can get the corner lights out of the car you're about halfway there. The next hardest part is getting the little rubber stopper out of the corner light. I drive a '99 so my corner light only had 1 connection. I just moved the wire from the 5w to the 27w connection and now my corner lights are brighter. Voila!
-hype
Old Dec 4, 2000 | 07:21 PM
metallic97gxe's Avatar
Master Will
Re: Questions
IDEA,Here is what I did. I don't like the soldering stuff,
I did this on my 1997 GXE
Take the lens out. Remove the bulb from the socket.Take a small flathead srewdriver and pry up on the little black plastic piece while pushing up on the wire in
the back(black with the red stripe). This wire is the to work with. The other wire(black) is just a ground and there is no need to mess with it. The wire(black
with red stripe)is soldered to the back of the little black plastic piece. Cut this wire
off of where it is soldered to,keep up with the spring so you won't forget it. This
wire will be spliced to the other connection. I drilled a hole straight through the
other side,through the solder and all and I took apart and old fuse holder,the flat
sides that look like a nail head this is where the contact point of the bulb will be.
Drill a hole big enough in the plastic to slide the wire from the fuse holder through
about 18 ga. size. Splice the fuse holder wire with a butt splice to the wire(black
with red stripe). Slide everything back into place and you should be set. The bulb
should shine brighter than it did in the beginning. All we are doing is lighting up the
high side on this dual filament bulb,by swapping contact points in the socket.
__________________
Old Dec 4, 2000 | 07:52 PM
tiedyemaxima
What are you doing when you rewire the corner lights?
Old Dec 4, 2000 | 09:50 PM
mzmtg's Avatar
Oops
I meant my parking lights and turn signals.
Sorry.
Old Dec 5, 2000 | 08:46 AM
JacksMax's Avatar
Re: Oops
Sorry.
So what did you do? Wire the front blinkers to come on dim with the lights? (see the link in my .sig)
Jack
Old Dec 5, 2000 | 09:09 AM
NiMax's Avatar
fog lights rewired
I live in North Seattle area and had rewired the fog lights. The fog lights can be turned on only with side marker on and they stay on with the high beams on. Of course you can turn off the fog lights anytime by its switch. It is not that difficult. It took me about 2 hours from start to finish including figuring the wire and covering the wire with black plastic cover.
If you need help, let me know.
Old Dec 5, 2000 | 10:13 AM
JacksMax's Avatar
Re: fog lights rewired
No thanks, did it. It was EZ! That was my 1st mod. See my sig below? I put what I did and a link to 'how to do it'.
Jack
Old Dec 5, 2000 | 10:36 AM
Chebosto's Avatar
RIceD OuT moDErAtor
Re: Questions
MaximaDriver dot com
JAY25
Sep 4, 2007 10:52 PM
beejo
Aug 17, 2003 11:59 AM
speedracer
21
May 22, 2001 02:44 PM
