Where is the EGRC Solenoid valve????
Old Jun 14, 2002 | 01:45 PM
bitebiscuits's Avatar
I am having trouble locating where to go in finding this item. This is the first car that I have personally worked on so I need some serious help. The ECU 1005 so I hope by locating the valve I can find out if that is the problem or not.
Old Jun 14, 2002 | 05:46 PM
MIXXMAX's Avatar
Re: Where is the EGRC Solenoid valve????
The EGR control solenoid is mounted at the rear of the left front cylinder head near the transmission dipstick. It has three air valves coming out of it. Very simple to replace. I found it easy to remove the air filter assembly. You have more room to work with your hands. When I replaced mine, it was difficult to remove the hoses. I found it easier to cut them and replace with new ones.
Old Jun 14, 2002 | 10:12 PM
Re: Re: Where is the EGRC Solenoid valve????
Thanks for the help-
You where right it is fairly easy to remove because it is right on top and easy to get to.
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
homeofbacon
Sep 23, 2015 07:17 PM
tardrex
Sep 11, 2015 07:35 PM
