Anyone ever try 255/35's on an 8" wide wheel?
255 will not fit on 8 inch.
255 will fit on 8.5 inch.
35 will give you NO SIDEWALL. You will tell your friends "my car handles like its on RAILS"...This is because on 35 profile, your RIMS will FEEL like RAILS on the pavement.
245/40 18 on a 18x8 with 40mm offset is perfect all around.
Check out JAY25's Homepage.
The most you can do if NOT a daily driver:
255/40 18 on 18x8.5 front and 265/40 18 on 18x9 (you will rub)
If you like it..check out UNCLEMAX.
255's will fit on a 8" rim, but is NOT recommended. juss like how a 235 will fit on a 7" rim but is NOT recommended.
245/40/18 is not really perfect all around, its a bit larger in diameter compared to stock. Ideally you want to try to get as close to stock overall diameter as possible so 235/40/18 would be a closer.
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
