Cat back exhausts and the O2 sensor relationship
Old Jun 18, 2002 | 12:12 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
I just ordered my y pipe from budget and am now looking to upgrade my cat and my catback exhaust. Since i would like to do all of the mods at the same time, I need a little info. . . Does the '98 SE have 3 O2 sensors in the exhaust and if they do, do i need a catback that accomodates these, or would i be fine w/o it? are there any other ways to work around this are do some have o2 holes already in them. another thing is what makes the best gains, medium sound and LOW COST. being on a budget SUX.
lets just make this simple
WHICH ONE SHOULD I GET?
thanks
STEVE
Old Jun 18, 2002 | 12:16 PM
ejj's Avatar
ejj
Re: Cat back exhausts and the O2 sensor relationship
thanks
STEVE
Yes, your 98 has 3 O2 sensors, with the thrid being after the cat itself. I've had an Apexi WS catback for quite a while (1 year+) and never had it modified for the rear O2 sensor. No problems (although the CEL was on). I just had a test pipe made with the fitting for the O2 sensor, so now its back in.
Bottom line...if you don't mind the CEL, you don't need to have that sensor installed.
Old Jun 18, 2002 | 12:20 PM
AdMax98's Avatar
The y-pipe has 2 o2 sensors and there is one more after the cat.
If your on a budget, then stick to just the y-pipe. Replacing the rest of the exhaust will produce minimal gains, only do it if you end up getting forced induction or if you want a louder car.
Old Jun 18, 2002 | 12:51 PM
slimer's Avatar
Re: Re: Cat back exhausts and the O2 sensor relationship
ok,but if i didnt want the cel on how would i weld the o2 back on?
Old Jun 18, 2002 | 02:14 PM
AdMax98's Avatar
Re: Re: Re: Cat back exhausts and the O2 sensor relationship
Cut a hole in the exhaust piping, weld a nut of the proper size, then screw the 02 sensor in.
JRod28
Dec 29, 2023 09:56 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
hot04
Aug 24, 2015 07:07 AM
sonic7
Aug 20, 2015 12:23 PM
09maxshawn11
Aug 14, 2015 10:07 PM
