Removing resonator on '98
Old Jun 23, 2002 | 09:28 PM
sgmax's Avatar
How much will the exhaust sound change if I just remove the resonator from the 98 stock exhaust and replace it with straight pipe? How does that compare sound-wise with leaving the stock resonator and b pipe and installing a Magnaflow muffler or something like that?
Old Jun 23, 2002 | 11:13 PM
98fiveSpeed's Avatar
resonator on a stock exhaust?
Old Jun 23, 2002 | 11:14 PM
JustTry's Avatar
im pretty sure it gets pretty loud, well a noticable difference, but beware of losing low end power (torque as some call it incorrectly)...
Old Jun 24, 2002 | 04:26 AM
Jime's Avatar
Darn, thats why I'm so slow gotta put that back on. Should I put the cat back in too instead of the one with the straight pipe through it?
Old Jun 24, 2002 | 09:08 PM
sgmax's Avatar
So, I'm getting the picture that this is a generally bad idea to take the resonator out - loss of low end power/torque? Would the increased noise level be under the seats or out the back of the car, since the resonator is under the seats?
Old Jun 24, 2002 | 11:09 PM
korupter's Avatar
the noise would be at the muffler since there is no hole or opening at the straight pipe.
Here's my question... does more air flow = more noise?
Old Jun 25, 2002 | 01:19 AM
joaquink's Avatar
¿Hablas Español?
Yes, this is why you are SO SLOW!! I hear that if you put banana
peels all over the b-pipe it will have the same effect as a resonator
and then put the banana in the tail-pipe to help increase your lost
back pressure. This should easily help you see those much sought
after 12s.
It's okay, no need to thank me - I'm here to help.
Old Jun 26, 2002 | 09:40 PM
sgmax's Avatar
Is the resonator straight through, or does it have baffles inside? If it is straight through, will it really make that much difference in low-end power? Will the factory muffler drone on the highway with it removed?
Old Jun 26, 2002 | 11:06 PM
WizzaMax's Avatar
I have to second that...I have a Stillen Y-Pipe, Stock CAT and resonator and MagnaFlow Mirror Finish muffler and it is loud...I can get a new resonator for $80 installed that should take care of the drone...sometimes it is unnoticeable and others it is even too much for me.
Old Jun 27, 2002 | 12:27 PM
Anachronism's Avatar
http://forums.maxima.org/showthread....5&pagenumber=1
Old Jul 7, 2002 | 09:52 PM
sgmax's Avatar
I'd like to get a sound similar to the Lumina Euro's or Bonneville SSE from the early 90's - like a burbling/powerboat sound. Will removing the resonator/leaving stock muffler make it as loud as those cars?
Old Jul 7, 2002 | 10:03 PM
1FSTMAX's Avatar
My cusin has a Olds with a magna flow, and that car sound like a little V8. To bad his car is still slow.
Also I removed my resonator, and did not feel a loss of low end torque.
Old Jul 8, 2002 | 09:25 PM
sgmax's Avatar
How did the sound change when you removed the resonator? Was it a large difference, or barely noticeable?
Old Jul 11, 2002 | 09:24 PM
sgmax's Avatar
Anyone??
Old Aug 18, 2002 | 08:51 PM
sgmax's Avatar
Has anyone who removed the resonator had a problem with exhaust leaking under the car? How do they keep the fumes out when the pipe is installed? Also, is it a better idea to replace res. with a complete B-pipe instead of having them do all that welding?
Old Aug 19, 2002 | 05:20 AM
Vinipux's Avatar
has anyone who has actually done this reply please, and those who say that you loose power, WHY THE HELL WOULD YOU? explain your reasoning or prove it using a dyno, otherwise "I think, you'll loose power..." statements are useless. a resonator is there to do what??? RESONATE, so it makes the car quieter, but how would that effect power, if anything it should give you power because the air flow is smooth through the pipe instead of bouncing the airflow in the resonator
P.S. and also, unless you have timeslips and dyno I don't want to hear I feel the car is slower/faster, I personally think the car is faster when I fill it up w/ gas, I know it's not true but it just FEELS faster
Old Aug 19, 2002 | 09:27 AM
Asian_N02's Avatar
I had a Greddy Catback installed on my car...the top end power was great...but it got too loud. I got tired of the resonating sound at 2500 RPMs. So, I installed a stock muffler. I felt a power loss at the top end of my RPMs, but it felt like I could accelerate quicker...
Old Aug 19, 2002 | 11:56 AM
2KxSEx's Avatar
Hey,
The sound of the exhaust will barely change. I've taken out my resonator when I went to have my rusted stock exhaust replaced. Not putting in a resonator saved me 30 bucks too
Peace.
Old Aug 19, 2002 | 09:27 PM
iregula's Avatar
intereseting
Old Sep 18, 2002 | 03:39 PM
Mark Reilly's Avatar
The saga of the Stillin B pipe
Last year I had Stllen install their SST "B" pipe and SST Muffler in my 96. At first I thought the difference in noise was neat, max was barking nice..grrrr!.... at the muffler, but inside the cabin with that drone at around 2400RPM......highway speed wouldn't you know in 5th. I finally had to install the stock resonator back in the "B".....now I hear the K&N intake more than the drone....it's a bit quieter inside. But to quiet it down even more inside.......a baffled muffler is required. So I'm livin with it at the current noise levels.
Old Sep 18, 2002 | 04:28 PM
97GLES's Avatar
Originally posted by 2KxSEx
Hey,
Peace.
i took of my resonator and felt no low-end power loss. at the muffler it has a little more sound to it. no extra noise in the car. in my case it made the car feel better on the top-end. all i have is cone filter with mid pipe and stillen y-pipe.
i too would like a cat-back but without the noise in the car, i have a 5 month old.
soon to come is a high-flow 2.5" carsound cat.
Old Sep 19, 2002 | 06:04 AM
StygianMax's Avatar
I did a swap with Jime's exhaust system so I can comment first-hand on the noise change between having a stock exhaust system with jwt pop vs. aftermarket one (exact details in first bullet point below).
Since the question of loudness with exhaust systems is pretty subjective (unless you have a sound meter to measure dB level at different frequencies) my answer is very subjective based on my tolerances & preferences.
  • the system I now have is comprised of: Budget y-pipe, hi-flow cat (not sure of manufacturer), Budget b-pipe (no resonator), & 2K1 Maxima muffler with 2.5" inlet pipe.
  • I'm a dad of 2 kids & appreciate quiet when cruising at constant speed esp. for long distance drives but like a nice bassy growl. Also, I don't find my jwt pop excessively loud when going WOT. This should set a bit of a "baseline" in my subjective comparison.
I find the jwt intake still to be the biggest noise-addition factor. When cruising, it is quiet to me. At WOT, the new exhaust system is slightly louder than just having jwt in place.
Has anyone who removed the resonator had a problem with exhaust leaking under the car? How do they keep the fumes out when the pipe is installed? Also, is it a better idea to replace res. with a complete B-pipe instead of having them do all that welding? [/B]
I don't have any leaks. My Budget b-pipe extends all the way from the rear flange of the cat to the muffler. You can see a good pic of this on pg. 5 of my cardomain website.
Hope this helps.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
