**ADDCO RSB HOW TO** (many pics)
Old Jun 25, 2002 | 09:25 PM
DigitalTexan2u's Avatar
Hi everyone,
I just installed the Addco RSB and thought i'd do a little write up on it...
Step 1:
Drag out the car ramps and back the Max on up. (Per John at Addco "the suspension should NOT be allowed to "hang" like if you were to simply jack up the car. He said to definately use ramps!)
http://www.imagestation.com/picture/...2/fd9b41ae.jpg
Now you are looking at a stock rear end!
http://www.imagestation.com/picture/...6/fd9b419c.jpg
Step 2: (optional)
Remove the *2* emergency brake line bolts (10mm) on each trailing arm. There will be 6 bolts total (3 on each trailing arm) **Just remove the rear most 2** (see pic) (I say optional, because I removed the passenger side bolts, but didn't on the driver's. You can do this mod without removing these bolts.)
http://www.imagestation.com/picture/...0/fd9b4188.jpg
Step 3:
Install the bushings by applying some lube to them(so not to squeak). Then gently "pry" the bushing apart with your hands to make it go onto the bar.
http://www.imagestation.com/picture/...9/fd9b41ab.jpg
Step 4:
There are **4** plates with this kit. The plates with the 2 "oval" circles go with the "U-bolts". The other 2 plates go with the [ & ] "square bolts" they have a "oval" and a "circle" in them. (the square bolts go onto the trailing arms...by the tires) See pic below:
http://www.imagestation.com/picture/...0/fd9b41a7.jpg
Step 5:
Install the U-bolts first...this way it mounts it to the car and you can easily move it around to mount to the trailing arms. I didn't tighten them up that much at this point.
http://www.imagestation.com/picture/...5/fd9b418d.jpg
Step 6:
Install the trailing arm bushings. This step is really easy! just make sure you put the bolts IN BETWEEN the brake line and trailing arm! Pinched brake lines aren't fun....
http://www.imagestation.com/picture/...8/fd9b4194.jpg
Step 7:
Install the 4 brake line bolts (10mm) back into the trailing arms.(If you removed them).
Step 8:
Tighten ALL of the 14mm bolts that attaches the RSB to the vehicle!
Step 9:
YOU DID IT!! It should look like this:
http://www.imagestation.com/picture/...8/fd9b4197.jpg
Just remember to take your time, and think it through...ANYONE can do this!
Here's what it now looks like from behind:
http://www.imagestation.com/picture/...6/fd9b4181.jpg
I am VERY pleased with the results from this bar...
The car seems much more level in the turns, and so much tighter out back!
Later!
Old Jun 25, 2002 | 10:44 PM
gtr_rider's Avatar
192.168.1.1
www.vqpower.com/rsb.htm
Old Jun 26, 2002 | 01:14 AM
Mad Dhan's Avatar
Finally, a good wirte up and install pics, the two have never met until now.
Old Jun 26, 2002 | 04:35 AM
Thanks!
I'm in agreement with you...that's why I took the time to post this.
Hope it helps someone.
Later
Old Jun 26, 2002 | 06:55 AM
Weasel's Avatar
Excellent writeup, but I'm wondering why Addco recommended the install not be done while the car is on jackstands? I supported my car at the 2 jack points in front of the rear wheels and the install went fine.
Old Jun 26, 2002 | 09:03 AM
97maximase5spd's Avatar
It's for safety purposes/avoid lawsuits. It's much safer than on jacks.
Old Jun 26, 2002 | 10:25 AM
ereet's Avatar
Must be nice to be able to get your car up on ramps I've never seen one that goes up at a shallow enough incline to let me up one.
Old Jun 26, 2002 | 01:33 PM
D-sta's Avatar
good stuff. I need to install my friends rear sway bar soon. thanks.
Old Jun 26, 2002 | 01:43 PM
NickStam's Avatar
good writeup, that's the way they should be done
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
doctorpullit
Mar 29, 2016 11:08 AM
bigfrank
Oct 1, 2015 12:51 PM
