Question about OverDrive?
Old Jul 1, 2002 | 12:16 AM
cuse97's Avatar
Does anybody know the difference between starting w/ and w/out OverDrive on a auto. I have a '96 GLE auto and I'm going to be racing this weekend at English Town, NJ and really wanted some tips on getting off the line. After serching I found a # of tips (thanks to all who posted) but none of them included or said anything about taking the O.D. off or leaving it on. Does it make a difference? Which is better?
Old Jul 1, 2002 | 12:20 AM
Nismo's Avatar
theres no difference at all unless you reach 3rd gear since all OD does is to keep it in 3rd once you get there.
Old Jul 1, 2002 | 12:45 AM
korupter's Avatar
i've heard that turning it off will switch gears at higher RPM, so i turned it off everytime i raced. I don't know if it's true though
Old Jul 1, 2002 | 02:06 AM
EZEMaxima's Avatar
OD button is for overdrive. Is it like another gear in your transmission. So keeping it off when racing would keep your RPM higher at the end of the track. Sometimes that helps to keep your motor in it's sweet spot peak hp/or torque.
Old Jul 1, 2002 | 02:56 AM
TurDz's Avatar
Sometimes, my old auto Maxima might hesistate between gears, especially during moderate freeway traffic, stop-and-go. So I figured out by restricting the gears to 3 (od-off), everything ran much more smoothly below 40 mph.
As of launching, I doubt there's a difference between using overdrive and not. If I were you, I'd just leave it on.
Old Jul 1, 2002 | 04:51 AM
GoldenGlory
indeed ... i concur...racing keep it off..till u hit about 120-130 click the overdrive n boom ..140...unless u got a limiter ..which will suck ...
dont drive with ur OD off all the time.... it will kill ur gas tank in a heartbeat !!
Old Jul 1, 2002 | 05:48 AM
Jime's Avatar
I leave my O/D on when racing at the track. The car doesn't get going fast enough to shift out of 3rd so it makes no difference. My car doesn't shift from 3rd to 4th until well over 6k just like the rest of the gears.
When street racing I guess its different I have no idea, Hommie don't play that.
Old Jul 1, 2002 | 05:53 AM
Cumalot's Avatar
For the track, let OD on. I tested this myself at the track and it made no difference whatsoever with OD on or off. Actually, maybe a little difference. I actually ran a slightly better time with OD on. Weird.
As far as the street or on the highway, I have tested this numerous times too. To me, it doesn't make a big enough difference, so I just leave OD on all the time now.
Old Jul 1, 2002 | 06:34 AM
Lime's Avatar
I actually got worse times with O/D off. And never turn on O/D when you're already going that fast...jeez...that's slamming the tranny into gear at the wroooong time. The only time I turn O/D on or off is when the car is stopped.
Old Jul 1, 2002 | 07:23 AM
H.N.I.C.95's Avatar
I disagree, I always race with overdrive off. You can fell the difference with the take off. Riding with o/d on is like a gas saver.
Old Jul 1, 2002 | 07:27 AM
Jime's Avatar
Gosh don't tell my time slip that.
Old Jul 1, 2002 | 07:30 AM
Cumalot's Avatar
Sure it "feel" faster, but I think that's just your mind playing with you. A few of us have prove this at the track. Try testing this at the track and then see if you still feel the same way.
Old Jul 1, 2002 | 07:52 AM
H.N.I.C.95's Avatar
try spinning out with o/d on and then off big difference
Old Jul 1, 2002 | 11:30 AM
DTR Maxima's Avatar
i always drive with my o/d on. you can test for yourself,but i also did numerous tests and i find my acceleration is much smoother, and the throttle response and pick up is dramatically faster, (especially at higher speeds) if i were you i would race with it on and do everyday driving with it on. i also have a 96' GLE just like you and o/d help a lot when its on.
just my 2 cents
Old Jul 1, 2002 | 11:41 AM
Dev's Avatar
Dev
it doesn't matter if O/D is on or off when racing...since you'll be flooring it anyways, the gears won't shift until redline. the only thing it does is keep the tranny from shifting into 4th gear, which means a lower top speed if you're going that fast.
for the most part, it won't make a difference though.
Old Jul 1, 2002 | 11:55 AM
Cumalot's Avatar
What does spinning out have anything to do with acceleration? You do know spinning isn't a good thing in racing right?
Well, do what you like. We have tested it at a track, not just butt dyno, so enough said.
Old Jul 1, 2002 | 12:46 PM
Lime's Avatar
Es ture.
I actually had a lower speed with the O/D off.
However, for random reference, when you are in O/D and going past about 110 mph, the car downshifts to go faster.
I didn't do this on a public road. Yeah.
Old Jul 1, 2002 | 01:25 PM
H.N.I.C.95's Avatar
More juice Baby and that is what you need al about looks
Old Jul 3, 2002 | 03:54 AM
cuse97's Avatar
It stays on!!!
Thanks to all who posted. I will be racing @ EnglishTown this weekend and i will have my O/D on. See ya there if your coming.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
