Need Help Wiwth Vi
Old Jul 6, 2002 | 08:02 PM
RS Motorsports's Avatar
NEED HELP WITH VARIABLE INTAKE
Aight i just installed my Vi and when i went to start the car it runs for a few sec and then just dies, I havn't done the vacuum or rpm switch and was wondering if the car should still run with out that on. please if anyone can help me out asap thatd be cool. Also as far as i know all the sensors and hoses are back on where they should be.
Ryan
Old Jul 6, 2002 | 08:38 PM
Mishmosh's Avatar
Re: NEED HELP WITH VARIABLE INTAKE
The manifold should definitely work without the RPM switch portion. Make sure all you connections have been snapped tight. Also, make sure all vacuum tubing has been secure. Still, even with a major vacuum leak, the car should not die after a few seconds... it'll run pretty damn rough but should idle nonetheless. My guess is that maybe one of your connections is not quite in.
Old Jul 6, 2002 | 09:05 PM
Re: Re: NEED HELP WITH VARIABLE INTAKE
Ya after i went to look at it some more one of my hoses wasn't on all the way, so it runs now, But should the car be idling really rough, i mean its bad right now, just wondering if thats normal.
Ryan
Old Jul 6, 2002 | 09:06 PM
NotNew!!NewSN!!'s Avatar
maf sensor
idle air control valve hose
any connections
any hoses
thats honestly all it can be, im leaning more towards the idle vacuum hose not being in, ur car cant idle without it.
Old Jul 6, 2002 | 09:15 PM
Also one more thing man, is it possible keep the butterflies open without having the vacuum on there cause i just want to compare to see what it feels like open. thanx for the help.
Ryan
Old Jul 7, 2002 | 05:11 AM
Mishmosh's Avatar
Ryan
To keep the valves open, just pull back on the vacuum lever and zip tie it in place.
As for idling rough, I think you should double check the vacuum lines. If it's not that, listen closely to the front upper-to-lower manifold gasket--with a stethescope if you must--there may be a leak there. Sometimes that gasket may not be perfectly aligned or the bolts holding the manifold down may not be torqued down tight enough. Sounds to me like there is a leak somewhere though...
DjCalvin
Audio/Video/Electronics
Aug 15, 2010 01:43 AM
