question about low/top end gain
Old Jul 10, 2002 | 01:27 PM
Jamsan's Avatar
when people say you get more low end back, or you get more high end back, what exactly is meant by that? for some reason, it just clicks in my head that top end means when your going faster, you get more gain there, and when your going slow, thats low end.....but to be corrected, top end gain means gains at higher rpms in all gears, and low end is gains in low rpm in all gears, correct? thanx for putting up with the ignorance
Old Jul 10, 2002 | 01:36 PM
98fiveSpeed's Avatar
correct, low end power = power delivered by the engine at low speed. High end power is when the engine is running at high speed.
Old Jul 10, 2002 | 02:14 PM
95/2k2:6Maxima's Avatar
I thought it was rpm
low end power to me always meant power id recieve at the lower portion of my rpms. High end power i wass lead to believe as power youd recieve in the upper rpms. For instances with headers on my 87 supra I recieved more torque in my higher rpms meaning more highend power. When I bored out my engine I recieved more power off the line meaning more low end power. I never applied it to speed because thats when gearing came to play. Like 4th versus 5th for 85 mph.
Old Jul 10, 2002 | 02:31 PM
MaximaRox's Avatar
i always thought it was rpm related too...never thought speed was in the picture
you can do 80mph in 3rd and be close to redline (high-end for rpms) or do 80mph in 5th and be between 3-3.5k rpm (low/mid range for rpms)
Old Jul 10, 2002 | 02:50 PM
Jamsan's Avatar
so anyone know EXACTLY which it is? im confused between the 2 as well
Old Jul 10, 2002 | 03:19 PM
Jamsan's Avatar
so, when i get my y pipe, i should feel gains at about 4.5-5 k rpm to redline in every gear?
Old Jul 10, 2002 | 04:37 PM
the "engine speed", i.e. the speed the engine is running at, which is measured in revolutions per minute(RPM), you must be confusing my explanation's refernce to "engine speed" as the speed of the vehicle itself.
Old Jul 10, 2002 | 05:00 PM
Sin's Avatar
Sin
Originally posted by slammed95
The y-pipe makes a noticable difference in power from 3000 to about 6300 rpm's. For some reason, at least in my car, it's a big difference between 2900 and 3000 rpms. Feels like when my friends S2000 hits the vtec point.
That's because our VQ's have variable valve timing on the exhaust valves, which just so happens to occur at around 3000rpm.
Old Jul 10, 2002 | 06:28 PM
Jamsan's Avatar
they sure do bro
Old Jul 10, 2002 | 08:59 PM
jcy98maxse's Avatar
Turbo is too much fun!
You must not have a 4th gen or you're misinformed. 4th gens have no variable valve timing at all.
we have vvt in our exhaust but not in out intake systems...
you can feel it sometimes if you pay attention rom 3000 rpm to 4000 rpm you can feel a slight jolt in power. (correct me if I'm wrong but I feel it in my 5 spd under wot)
Old Jul 11, 2002 | 08:48 AM
Sin's Avatar
Sin
I have had my engine apart with the timing chain covers off, cam sprockets off and valve covers off. The cams are solidly mounted to the sprockets. Also the intake and exhaust cam sprockets are connected by small chains. There are no mechanisms to alter valve timing anywhere.
It's done pneumatically.
alahjahwan09
18
Sep 21, 2015 09:12 PM
Hdnseek
Sep 9, 2015 05:55 AM
Adoubi21
Dyno Discussion and Slips
Sep 7, 2015 09:34 AM
Maxboy23
Sep 4, 2015 06:04 PM
