WTB: idle air control valve on throttle body
Old Nov 14, 2007 | 05:19 PM
nsnrider's Avatar
I need the idle air control valve for a 2000 maxima. It is located on the buttom of the throttle body. Need it to be in good working order.
Old Nov 14, 2007 | 09:10 PM
gxe2se's Avatar
b4 you dump money into the IACV.... check your MAF.
I had the same code thrown on my '00 SE - p505 IACV. Ended up being just a bad MAF.
Symptom: when engine warm, engine would die. stop light etc.
Good luck,
Anthnoy
Old Nov 15, 2007 | 04:29 AM
nsnrider's Avatar
Good luck,
Anthnoy
my symptoms: P0505 code along with another code (idle system malfunction), its fine when engine cold, when it worms up, rpm's fluctuate from 1200 rpm-2200 rpm. I checked the valve manually and it is siezed. Cut it in half to manual turn it, reinstalled it, now the engine holds steady 750 rpm when warm, but no idle when cold, have to constantly tap on the gas before it reaches operating temp.
thanks for the heads up.
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
lux97Max
Sep 4, 2015 05:42 PM
