FS: 5th gen Tokico Blues with Eibach Coilovers Ground Control 15k miles.
For Sale Tokico Blues with Eibach Coilovers 15k Miles i Dont know the drop its for my friend so i am selling it Asking Price $400 OBO + Shipping. just the kit costs $399 without the struts.
Specs and information:
Description:
This kit fits 95- Nissan Maxima with stock, Sachs, Boge, Tokico Premium Performance, Koni, or KYB AGX shocks (please specify shock type before ordering).
trimming of stock spring seat allows added range of adjustment
Expected ride height change from 0 to 3 inches
Ground Control Spring Kits
This spring kit gives you the option to customize the ride height of your vehicle. After several years of use in racing applications, Ground Control spring kits have been adapted for street use. Most other spring kits offer only one set ride height when installed. The Ground Control system's unique design allows for easy adjustment. Simply lift the corner(s) of the vehicle that you wish to adjust and spin the adjustable spring seat up or down to raise or lower the vehicle*. Ground Control spring kits are also designed to be used with either stock or aftermarket shocks.
*Some applications require the use of a provided wrench.
Springs: We are pleased to announce that Eibach has chosen Ground Control as the west coast distributor for their ERS (Eibach Race Spring) line of springs. All of our ride height adjustable kits now exclusively feature Eibach springs. All racing and street/show spring rates are available. All Eibach springs offer a lifetime warranty against spring rate change and sagging.
Adjusters: All adjusters consist of a threaded sleeve and adjustable spring seat. And are made using high strength 6061-T6 aluminum; anodized for greater durability and appearance. The threads on the adjusters are square cut which locks the adjustable spring seat in place under load. For further precaution, a setscrew in the adjustable spring seat can be used to secure adjustment. Upper spring perches are used to insulate the spring.
Ground Control works very hard with Eibach USA to make these springs to the standards that you demand. Lifetime guarantee on everything, not just springs. No excuses about "racing" or "special". If anything fails, while being correctly installed, it will be taken care of, period. We can only have a guarantee like this because every single part of the Ground Control Street coil-over kit is made by us or someone we trust. None of these parts are made in Taiwan. Everything is made in the USA.
Description:
morteljc
Oct 19, 2015 10:47 AM
Finkle
Sep 27, 2015 09:53 PM
doobadoo
Aug 15, 2015 06:43 PM
