Parting Out SC/Suspension/Exhaust/Tuning/Wheels/etc.
Old Jan 18, 2009 | 07:12 PM
NewfoundlandDud's Avatar
Please keep all offers to PM
IF YOU DON'T LIKE MY MODS/PRICES KEEP IT TO YOURSELF OR PM PLEASE
Mod List: (All Bought this year!)
Supercharger Kit: $3500 (Price Drop to $2500 + Paypal & Shipping.)
Complete Stillen V2 Kit with Vortech V2-SC Trim Centrifugal Supercharger with 3.125" Pulley (11psi) has had it's re-build by Vortech (previous owner)
3.125" pulley, 3.33" puley, 3.6" pulley
Matty's V1 conversion kit with modified Nissan thermostat housing, etc. (Much better kit, no belt Shred)
Stillen 5th Gen Maxima SC Kit with 5th Gen Charge Piping, Stillen Cone Filter, Coolant Reservoir relocation kit, etc.
Stillen fuel management system with 8:1 FMU Disk
All boost signal & electrical connections for the fuel management system
NGK 1 Step Colder, 0.037" Gapped Plugs
Custom Power Steering Cooler + lines
5-way Vacuum manifold & all Vac lines
Crank Case Breather Filter with breather lines for the VIAS, and ambient air signals
Braided oil line & oil T to supply the Supercharger
Idler Adjuster Pulley Bracket
Cam position sensor re-clock bracket
All the little parts that you need, bolts, hardware, brackets, lines, etc.
Any support that you'll need for the install.
Tuning: SOLD
I have a full Innovate system that I've been tuning with an Apexi NEO, and it all hooks up to your laptop for real-time logging while tuning. Innovate came out on top of all other Wideband systems in an independent study that was done last year. (Best accuracy, latency, display, usability, etc.) Here's the quick version, I have the full version if anyone needs it.
Here are the spec's:
1) Apexi NEO - 32 tuning points or 16 in simple mode (Tuned to a pretty flat 11-13 AFR on the Merlot Max, same tune for the Black Max). This unit will come with a harness from Apexi to tie into the Maxima ECU and keep track of all relevant sensors. The NEO will display RPM, Throttle position, Voltage, air flow %, and some other things that I can't remember off the top of my head. Most importantly, you can program the air/fuel tuning tables/curves right on the unit in seconds to adjust your tune while out on the street. You can also do some cool stuff like set the custom colors to like maybe 10 different colors or something like that, and set different "screen saver" backgrounds.
2) Innovate LM-1 (For Data-Logging your A/F ratio & tuning). This unit is transferable between vehicles and logs the data from the wideband. You can just hit the record button on the unit and it records up to 45 mins of data before you have to hook it back up the your computer. It also comes with LogWorks 2.0 for graphing and analyzing all of your tunes. You can actually display all the gauges in real time on a laptop from the car.
3) Innovate Wideband + Running cables - Wideband unit with custom heat-sink plus all running cables to connect to the head-unit.
4) Innovate LMA-3 (Expands your data-Logging and real-time streaming to include RPM, Throttle Position, G-forces XY, Any Sensor You Want from your car that has an output to the ECU, or controller). This unit really makes the tuning in LogWorks meaningful, and you will actually begin to understand what the tune is all about. This can even tell you if you have a misfire, etc.
5) Custom Maxima 3-Pod A-Pillar for your gauges (The pillar between the door & windshield)
6) Innovate DB-Red (Air Fuel Ratio Gauge) that interfaces with the LM-1 and LMA-3 to give you your A/F ratio in your gauge pod.
7) Wire-kit from Innovate to hook the LM-1, LMA-3, Wideband, DB Red gauge, your lap top, etc. etc. all together to make one system
8) Prosport tinted Electric Boost Gauge (With "Starting ceremony") - Superwhite/blue in the night
9) Prosport Electric Fuel Pressure Gauge (With "Starting ceremony") - Superwhite/blue in the night
All wiring & connectors to wire everything up together
10) Vacuum line to send your boost signal to the LMA-3
11) Fuel Pressure Signal Sender (for the engine bay)
12) Log Works 2.0 Software
Brakes: SOLD
13" Brembo Cobra Rotors up front - Slotted
J30 Calipers, Painted Black with Stainless Steel Braided Brake Lines
PBR/Axxis ceramic pads all around
All brackets & hardware
Suspension: SOLD
Tokico Illumina 5-Way Adjustable Struts
Progress Lowering/Sport Springs
KYB Strut mounts all around (Will allow removal & installation as a unit instead of tearing down your stock suspension setup. This saves time, labor, and you'll get some $$ for your stock suspension setup).
Progress Rear Sway Bar
Generic "Carbon Fiber-style" Front Strut Tower Bar (Sold)
Wheels: SOLD
Like New Forged 18x8 (5x114.3) SE-R Wheels
Bridgestone Potenza S-03 Pole Position Tires (Need replacement)
Exhaust: $Offers (It cost me $1585 for the system)
Warpspeed Y-pipe to Full 2.5" Stainless Mandrel Bent Magnaflow Exhaust
I removed the Magnaflow muffler in September and went back to the stock dual outlet, and it sounds much better.
Magnaflow Hi-flo cat (2.5")
Magnaflow 22"/26" Resonator (2.5"/4")
Custom Fab 2.5" Mandrel Bent Stainless Steel piping
Extra Transmission Mods:
Extra Auto I30 Transmission - VLSD $Offers (The local Auto-parts network charges $3500, I'd take probably $1000?)
B&M Short Shifter Sold
Pics:
Old Jan 18, 2009 | 07:13 PM
Old Jan 18, 2009 | 10:12 PM
Scottwax's Avatar
That's Mr. Detail to you
What do you want for just the rear Progressive anti-roll bar?
Old Jan 18, 2009 | 10:54 PM
MIK3's Avatar
What color are the wheel locks and are you willing to part them from the wheels?
Old Jan 19, 2009 | 12:05 AM
ser_altima's Avatar
**** bro I just bought G35 18" wheels damnit I woulda picked those up.. I may sell my G35 wheels and take these off your hands I had an SE-R and effing love the rims.. I REALLY REALLY may have to sell the G rims I just bought to take those. Do they come with tires and if so how good is the tread??
Old Jan 19, 2009 | 04:20 AM
All questions/pm's replied by pm.
Old Jan 19, 2009 | 06:34 AM
nissandrvr98's Avatar
what do you want for the strut bar?
Old Jan 19, 2009 | 07:11 AM
phatboislim's Avatar
HOW MUCH FOR THE SPRINGS?
Old Jan 19, 2009 | 02:23 PM
megalos's Avatar
how much for y pipe and sway bar?
Old Jan 19, 2009 | 03:53 PM
Hey I've replied to all pm's and all questions on here by pm. I got upwards of 30, so if I didn't quite get you all the info you wanted, get back to me, I keep having to clear out the inbox.
Phatboislim, I don't really want to part the springs from the Illumina's and KYB mounts, but if I decide to go that route I'll get back to you. There's been quite a bit of interests in the set, so I want to try that way first.
If anyone has any more Q's, get back to me via pm.
Old Jan 19, 2009 | 06:01 PM
Jarad's Avatar
How much for the springs and struts together? Is shipping included?
Old Jan 20, 2009 | 11:29 AM
s1mply_v's Avatar
Are you willing to part with the Stillen FMU and its wiring?
Old Jan 20, 2009 | 12:02 PM
No, sorry.
Old Jan 20, 2009 | 01:25 PM
FSTB Sold.
Old Jan 20, 2009 | 09:53 PM
VqMoNsTeR's Avatar
illuminas? 20785
Old Jan 21, 2009 | 01:46 AM
Not parting the struts alone right now.
Old Jan 21, 2009 | 02:09 PM
My Inbox has been nearly full all week, so I had to keep deleting messages. It's still right at capacity right now.
Whoever was interested in the springs/struts/mounts parted out, sorry I didn't get back to you but I don't have your pm's there anymore, and I don't know who to contact.
e-mail me at thatguycole@hotmail.com and I'll part if I can get a buyer for everything lined up. OBO
Old Jan 21, 2009 | 03:41 PM
Wheels are "dibbed" for a week or so.
Old Jan 22, 2009 | 01:15 PM
More Stuff!!
Brand New Autometer Transmission Temperature Gauge
I bought this for the S/C Auto Maxima, but ended up swapping to a 5 spd, so it's brand new in box
I opened it to make sure that everything was in there, that's all
$100
Autometer Pyrometer Gauge (EGT Gauge)
Includes Sensor, Wiring and Mounting Equipment, etc.
SOLD!!
Autometer Fuel Pressure Gauge
Needs a new sender
$30
Window Visor/Vent Things
They came off of my Maxima
Pretty sure they're kind of universal
They're $81.99 at Canadian Tire new
$20
"Carbon Fiber Style" Battery Cover - Universal
$15
The CosmoRacing Plate Cover is Free!!
Eurolite Red Xenon Bulbs - 1157
Brand New
$10
Charge Capacitor / Starter Assist Thing - Came with a Groundwire Kit I bought
SOLD
Garmin eTrex Legend GPS
I've never used this, it was given to me about a month or two ago
I took it out of the box to put some Energizer batteries in it, and turn it on to make sure it worked
It works great, it can locate you using satellite maps, and even track your trips, giving average speeds etc.
These are great little GPS's, they're fully water proof etc.
I think they sell for about $170US
I'll let it go for $100
Old Jan 23, 2009 | 10:39 PM
ckent512's Avatar
How much for the progress rear sway bar to 78727?
Old Jan 26, 2009 | 08:22 AM
LM-1 possibly spoken for.
Keep the offers coming.
Old Jan 26, 2009 | 10:00 AM
Originally Posted by NewfoundlandDud
FSTB Sold.
yay--on its way yet?
Old Jan 26, 2009 | 10:15 AM
Yeah I shipped it out last week. I thought that I sent you your tracking number, I'll have to get it and send it again tonight after work. Sorry about that.
Old Jan 27, 2009 | 02:27 AM
The guy that "Guaranteed me he wouldn't back out if I held the wheels for him" decided to back out yesterday, funny hey. So the wheels are up again, and ready to go.
No more "dibs", whoever is ready to buy will get first shot at everything.
Price Drop*
Suspension for $800 without the RSB.
Serious buyers only, pm me for more info.
Old Jan 27, 2009 | 06:17 AM
Tippy Toes's Avatar
I'm a serious buyer if you want to sell your struts and dust boots.
Old Jan 27, 2009 | 08:36 AM
Sorry, I want to sell the suspension combined right now.
Got a few guys interested, I'll post up if I do decide to part, doubtful though.
Old Jan 27, 2009 | 06:03 PM
viperboy's Avatar
Willing to sell only the Magnaflow muffler with tips? How much shipped to 18067? And I'm assuming it's offset 2.5 and center 2.5? Thanks
Old Jan 27, 2009 | 06:33 PM
Sorry, the muffler w/ tips sold a little while back.
Thought I outlined that in the "to stock muffler" description.
My bad.
Old Jan 27, 2009 | 06:38 PM
viperboy's Avatar
Oh, alright. Thanks anyway and G/L!
Old Jan 28, 2009 | 02:26 AM
RSB is $120
Come on now, I get 10 pm's a day from people that want this stuff, but have to wait until the end of the week & such.
I have to make a deposit on my next car, lets get some of this stuff moved.
Old Jan 28, 2009 | 09:17 AM
Suspension Setup (Not including RSB) is held right now, awaiting payment details. I'll update if it falls through.
LM-1 is also "held" for the new dad, until he gets a minute to sort it all out. lol
Accepting offers on everything else.
Old Jan 28, 2009 | 04:46 PM
throttlehappy46's Avatar
How much for just SE-R wheels, no tyres?
I can arrange my own freight to Australia.
Old Jan 28, 2009 | 04:52 PM
cole's Avatar
wow, some great parts here...
if i didn't have a $300/mo payment for my camaro, i'd love to pick some of this stuff up
Old Jan 29, 2009 | 02:03 AM
Suspension Sold.
SE-R's and RSB still available.
Everything listed still for sale!
Old Feb 5, 2009 | 08:31 PM
Bump.
Old Feb 18, 2009 | 02:44 PM
Bump this stuff.
I'm trying to buy a car this week, and it would be good to get some stuff out the door.
Old Feb 18, 2009 | 05:01 PM
RSB sold.
Old Feb 19, 2009 | 06:25 PM
Now accepting reasonable offers on everything.
Willing to part some stuff, serious buyers can pm for details.
Old Feb 22, 2009 | 04:42 PM
All Tuning Equip pending deposit.
Taking offers on everything else.
Old Feb 25, 2009 | 05:52 PM
Tuning Equipment Sold!
Waiting on the rest of the payment.
Taking offers on the rest.
Flexible.
