NY FS: 03 Maxima Fresh Leather Seats (Frost)
Old Dec 21, 2010 | 05:25 PM
luvlexus101's Avatar
Asking 450 obo - willing to drive 50 miles to meet up with a buyer - more pics available upon request
Selling my leather heated seats out of my 2003 Maxima TE
Seats are fully functional and the heaters work
Will include two switches if needed.
I'm in queens, ny.
Old Dec 21, 2010 | 05:26 PM
Stormzusmc's Avatar
glws what you end up getting instead?
Old Dec 21, 2010 | 05:31 PM
Just going lightweight...lol jk
i35's with heated backseat and sunshade
Old Dec 21, 2010 | 07:55 PM
vastmax's Avatar
hoping to help the seller and the org out:
to whoever buys these seats, if you want to have a more 'complete' package, I have the matching door panels, IM me
luvlexus101, if you'd like me to remove this, no problem
Old Dec 24, 2010 | 12:12 PM
Its cool, someone make an offer I need to move these
Old Dec 25, 2010 | 05:58 AM
Intrepid1's Avatar
What is the condition? pics look good, but are there any cracks, tears, stains, burns, etc?
Old Dec 25, 2010 | 08:54 AM
Nope there's none of that! These bad boys are in great condition, I'd rate them all 9/10 except the driver seat more like an 8/10(little more wrinkling and such from being used most) but there are not cracks tears burns or stains of any sort!
Old Dec 26, 2010 | 06:25 PM
2kVQboodah's Avatar
these fit in 5gen 00-01 maximas? my car also has heated w/ leather
Old Dec 27, 2010 | 07:47 PM
Hm, not sure, I think the wiring is different.
Old Dec 27, 2010 | 10:21 PM
bygblok's Avatar
dammit I wish I could get those to Pensacola..........sure would be a nice add-on to my 02!!
Old Dec 28, 2010 | 05:21 AM
Mr Yaaoowwa's Avatar
bump for NY
Old Jan 4, 2011 | 05:37 PM
I'm coming down there for spring break maybe we could make it happen
Anyway bump I'm asking 400 obo, I can meet up within 100 miles or so, lets do this.
Old Jan 5, 2011 | 08:09 AM
Ishqkapujari's Avatar
yes they will fit.. rears are no problem. u would just have to replace the power and heated solenoid on drivers... passengers is just the power i believe... (i have 03 black leather seats on my 01)
BUMP FOR QUEENS!!!!
Old Jan 9, 2011 | 12:16 PM
bumpppp i need these gone.
Old Jan 10, 2011 | 08:10 AM
Bonez21's Avatar
GLWS but question...do the i35's fit in an 00-01 max? I had a chance this past summer to scoop those and ended up only taking the switches....smh...
Old Jan 10, 2011 | 10:25 AM
OOmaxSE's Avatar
Been searching up on the forum for corresponding wires/diagram to swap these over to my non-heated 00-01 cloth. Can't find much-- any help, as I'm interested in buying as soon as I can figure this little dilemma out.
Old Jan 10, 2011 | 10:44 AM
As far as I have figured out, yellow should be power, and black should be ground. Beyond that I'm not sure if you need to hook up anything else for the general functioning of the seat. For heat I believe you'll need only two wires to go to the switch, one for high and one for low. The switch has 4 wires each, I'm assuming - ignition, high, low, ground. Anyone else wish to chime in? I want these gone.
Also I have 4 i35 door panels for sale - would anyone be interested in them? I'll post up pics if there's interest - they are in great condition.
Old Jan 11, 2011 | 08:34 AM
gotendbz1's Avatar
not looking for any seat back i'm guessing?
Old Jan 11, 2011 | 10:28 AM
ewakefield's Avatar
youre right there are 4 wires running into/out the switch on a 5.5's heated seat. Ill try to find the diagram and post it...i have it somewhere
Old Jan 11, 2011 | 04:14 PM
OOmaxSE's Avatar
Is this the 02-03 wiring?
white/red +12V - tap this into the white/red from the original 2 wire harness
YELLOW/BLUE +12V - tap this into the white/red from the original 2 wire harness
BLACK GROUND - tap this into the black from the original 2 wire harness
Red/green Needed for the "automatic drive positioner". Supposed to get 12V when the key is in ignition.
light green DOOR SWITCH - WORKS WITH GROUND - also needed for "automatic drive positioner"
Here is the 00-01 wiring (thanks Dennismik). Can't seem to find the 02-03 though...
As I read the FSM for the 2000 Max, the connectors in the console for the switches are 4 wire connectors, square shaped.
Driver's seat switch:
Pin 1 - Green with red stripe - 12 volts from 10 amp fuse # 9
Pin 2 - gray - to seat heater element # 1
Pin 3 - gray with red stripe - to seat heater element # 2
Pin 4 - black wire - chassis ground.
only needed for indicator lights built into the switch.
Passenger seat switch:
Pin 2 - gray with ??? stripe- to seat heater element # 1
Pin 3 - gray with black stripe - to seat heater element # 2
In low heat mode, only heater element 1 is used (pin 2).
In high heat mode, both heater elements are used (pins 2&3).
Old Jan 11, 2011 | 05:19 PM
From what I have seen in the 03 fsm..
Yellow goes to power, black goes to ground.
For heated seats you just have to connect the wires to the switches(matching colors) and then run power and ground for the switches.
Old Jan 11, 2011 | 08:53 PM
ewakefield's Avatar
According to the diagram im looking at for an 03 its is the same as this so im assuming they are the same in 5 and 5.5 gens
Old Jan 11, 2011 | 08:55 PM
ewakefield's Avatar
would you be willing to part with a drivers heated seat switch? if so, pm me.
Old Jan 11, 2011 | 08:56 PM
Great someone come get these now!
Old Jan 11, 2011 | 08:57 PM
OOmaxSE's Avatar
Thanks ewakefield, I'm assuming they just aren't plug and play-- so splice them to the same colors?
To the OP, are these memory seats?
Old Jan 11, 2011 | 09:03 PM
They are indeed, I have the switch modules as well however I was planning to include them in another sale for the 2003 i35 door panels.
Old Jan 11, 2011 | 09:54 PM
OOmaxSE's Avatar
I'm asking because it's actually much harder to install the MS and would be a better idea to ditch the module under the driver seat.
Where does 100 miles end up being in the direction of 01002?
Old Jan 11, 2011 | 11:41 PM
Hartford is about 120 miles up, seems to be about halfway, I could do that
Old Jan 17, 2011 | 07:00 PM
kvlar78's Avatar
I will give you $200 cash for the fronts seats only. I'm on SI and can pick them up from you
Old Jan 17, 2011 | 08:13 PM
BLUEMAX01SE's Avatar
Darn! I need frost leather in my 01 AE. Mine are torn and ripped and yours look to be in very great shape! I wish I was closer to pick those up from you! I'm in Chicago! glws! I'm missing out!
Old Jan 17, 2011 | 08:32 PM
Ahh these are more or less spoken for unless buyer backs out on me
Old Jan 17, 2011 | 10:15 PM
dcskater584's Avatar
pm sent
Old Jan 18, 2011 | 10:49 AM
kvlar78's Avatar
Let me know if smthg changes.I will pick them up from you and pay cash
Old Jan 19, 2011 | 11:52 AM
OOmaxSE's Avatar
Still here
Old Jan 19, 2011 | 11:05 PM
036mtmax's Avatar
pm me if still available,thanks
Old Jan 28, 2011 | 10:10 AM
Bump to top, potential buyers PM me an update
Tbone3944
Sep 29, 2015 09:04 PM
rtirbany
Sep 8, 2015 11:46 AM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
Wolvee
Aug 11, 2015 12:24 PM
