Pics of the Slotted/Dimpled rotors on the car
Old Jul 10, 2002 | 06:25 PM
BigDogJonx's Avatar
Here are a few pics of them on the car. They look AWESOME. That is all I can say. Unfortunately I could not get the rears off cause they were stuck. I gotta get some WD40 and my hammer from my brother to get it off. Until now, the fronts will do till tommorow evening.
I have not been able to ride hard on them since I am trying to "break" them in slowly. Will let everyone know how they stop in a week.
Pitures of the rotors out the box and Installed are HERE!!!
Dixit
Old Jul 10, 2002 | 06:29 PM
Greg's2kGLE's Avatar
Dimple rotors....I have never seen those. Interesting. How much were they?
Old Jul 10, 2002 | 06:39 PM
BigDogJonx's Avatar
http://forums.maxima.org/showthread.php?threadid=132897
Order it there for $200 all 4.
Dixit
Old Jul 10, 2002 | 09:53 PM
Driven EF9's Avatar
Dixit
why did you get them? they are pretty cheap, but i'd question their functionality... unless you're just in it for the look, then it's a good deal!
Old Jul 10, 2002 | 09:58 PM
20 MAXIMA 02's Avatar
the screw on your rim is rusting
BigDogJonx's Avatar
You telling me you are questiong their functionality based on it being slotted and dimpled? You are wrong son.
These are prooven by professional dragsters. They are good and better than cross drilled. Cross drilled crack too easily under high heat stress.
I got them both for functionality and cosmetical. Aint nothing wrong with that.
Dixit
Old Jul 10, 2002 | 10:03 PM
BigDogJonx's Avatar
Since you pointed it out, why not get me a new set of 4 then.
Dixit
Old Jul 10, 2002 | 10:07 PM
KLOOGY's Avatar
L33t BMW Drivah
Dixit
Come on Dix.. you'll be rolling on DUBs in no time... !
Old Jul 10, 2002 | 10:13 PM
BigDogJonx's Avatar
Soon enough we will all be rolling on Dubs
Maybe just me.....
Dixit
Old Jul 10, 2002 | 10:16 PM
KLOOGY's Avatar
L33t BMW Drivah
Maybe just me.....
Dixit
I would already be dubbed , but I still want to race !
Old Jul 11, 2002 | 07:35 AM
got rice?'s Avatar
You have the rotors on the wrong side.
Old Jul 11, 2002 | 08:34 AM
Cutler's Avatar
I think Phoung is right, slots are supposed to be facing forward
Old Jul 11, 2002 | 08:36 AM
BigDogJonx's Avatar
What? You telling me I got them backwards? I did not these things went on one side only.
How you know?
Dixit
Old Jul 11, 2002 | 08:54 AM
K Pazzo 6's Avatar
Old Jul 11, 2002 | 09:43 AM
TimW's Avatar
The silent but deadly Moderator
man..
I thought that too... but I didnt want to look like an idiot.
Old Jul 11, 2002 | 09:45 AM
y2KAOSMax's Avatar
Re: Pics of the Slotted/Dimpled rotors on the car
Dixit
Did you get new pads too?? If so what kind??
Old Jul 11, 2002 | 09:48 AM
BigDogJonx's Avatar
Re: man..
So they are clearly on the wrong side. Son of a.......... well it is a ten minute job to switch them around. No biggie, I gotta do the rears tonight anyways. Got to get the stock rears off for sure this time.
Dixit
Old Jul 11, 2002 | 11:26 AM
TimW's Avatar
heh
I just thought it looked wrong. I wasnt sure.. if I had *known* for sure I would have let ya know. Easy mistake I would think.
Old Jul 11, 2002 | 11:38 AM
BigDogJonx's Avatar
Re: heh
They looked more normal to me that way since they sort of matched the way the spokes are on my rims.
dixit
Old Jul 11, 2002 | 11:42 AM
srbarnes4ever's Avatar
Re: Re: heh
dixit
So which side should sit on the hub? I always assumed the vanes on a vented rotor had to be a certain direction but never knew for sure....
Old Jul 11, 2002 | 12:31 PM
BigDogJonx's Avatar
Re: Re: Re: heh
The rotor itself can only fit one way on the hub itself, but they can be mistakenly put on the wrong sides of the car as I did right now.
Dixit
Old Jul 11, 2002 | 06:57 PM
Driven EF9's Avatar
Kinda like putting the rotors on the wrong side of the car?
cause, dragsters know a lot about braking systems over road racers.
These are better than x-drilled, but still worse than a rotor like a brembo blank.
You speak of high heat stress... the rotor absorbs and dissipates heat... remove material from the rotor and it can no longer absorb the heat as well as a blank rotor. The only thing the dimpled and slotted rotors (or x-drills) are remove the gas build-up between the pad and the rotor...
overall, there's no improvement on braking distance whatsoever. And i'm sure you don't road race the car, so brake fade isn't a concern...
but, they do look purdy and they are truly a great price for those rotors!
Old Jul 11, 2002 | 07:40 PM
BigDogJonx's Avatar
Well as you can see from the responses, anyone could have made the mistake of putting them on the wrong sides. I have correct that today and also did the rears. Everything in 1hr flat. If I had my impact wrench, i swear it wouldve been 25mins.
Dixit
Old Jul 11, 2002 | 07:41 PM
BuddyWh
... The only thing the dimpled and slotted rotors (or x-drills) are remove the gas build-up between the pad and the rotor...
The principle sounds good... but I wonder if the dimples could become fouled with with brake dust (or something) in operation. It also appears to me the dimpling and slots effectively reduce swept area quite a bit.
And... finally... who made the blanks for these rotors? I seem to recall Stillen gets Brembo blanks for their x-drilled rotors, but could be wrong.
BuddyWh
Old Jul 11, 2002 | 07:52 PM
BigDogJonx's Avatar
BuddyWh
If you get the 3rd-4th gen, you get Brembo front and EMC rears, 5th gens get EMC front and rear blanks.
EMC is some company like brembo but bigger in the asian market.
Dixit
Old Jul 12, 2002 | 12:05 AM
K Pazzo 6's Avatar
Dixit
post pics now....
Old Jul 12, 2002 | 12:26 AM
BigDogJonx's Avatar
Originally posted by K Pazzo 6
post pics now....
Been posted, I just changed the files in that same directory. Updated them when I posted the reply like 4hrs ago.
Dixit
Old Jul 12, 2002 | 04:14 AM
2000SEMAX's Avatar
Hey hows the breaking feel (Im sure its 100X better then stock) Lets us know how they feel after the break-in time is up. Also what type of pads did you use?
Old Jul 12, 2002 | 08:14 AM
TellschMax02's Avatar
Read This!
Rotors 101
I think they look great, just question any performance benefits.
Brian
Old Jul 12, 2002 | 10:01 AM
BuddyWh
Re: Read This!
Originally posted by TellschMax02
Rotors 101
Excellent link! I thought I had read that somewhere and couldn't remember the site.
BuddyWh
Old Jul 12, 2002 | 09:45 PM
Driven EF9's Avatar
that's a good article... i just wish more people heeded this.
what improves braking distance:
a. bigger brake rotors
b. larger brake pad surface
c. better brake pad compounds
d. stickier tyres
e. slotted/dimpled/x-drilled rotors
f. more clamping force on the pads (ie. 4 piston calipers)
g. stainless steel brake lines
h. higher boiling point brake fluid
if you answered d., you are correct.
NOTHING ELSE ON THAT LIST IMPROVES INTIAL STOPPING DISTANCES. They DO, however, contribute to preventing fade to some degree, modulation of the braking force applied, eliminating rotational mass, longer lasting brake equipment, etc etc.
So, like i said in the beginning, these rotors are 95% cosmetic, 5% in the name of performance.
Old Jul 12, 2002 | 10:19 PM
BigDogJonx's Avatar
Look enough of the freagin remarks. I got these rotors cause they look nice and they will perform better than my stock rotors when I try to stop from 100+mph.
I aint taking it to a Nascar track.
Dixit
Old Jul 12, 2002 | 10:48 PM
TimW's Avatar
Dixit
its ok.. We appreciate your effort on the group deal, taking pics and just trying to help everyone here with our crappy rotors.
Being that you paid ALOT less for your rotors than stock, the whole performance/cosmetic arguement is kinda moot.. its not like you paid for something you arent getting.. you are getting nice new rotors to stop with.. obviously they do that fine.
Lakersallday24
Jun 16, 2019 01:35 AM
03VQMAX
Sep 25, 2015 04:19 PM
halfpol
Aug 5, 2015 08:24 PM
RealityCheck
Aug 5, 2015 06:18 AM
