Would some one explain.....
what the hell this is http://cgi.ebay.com/ebaymotors/ws/eB...tem=1843634034
how is a freaking O2 sensor gonna at 15hp. and no im not gonna get it and try it out so dont even try guys
Re: Would some one explain.....
Here's what I like... search on "O2 SENSOR RECALIBRATOR 15HP" (leave off Maxima) and you get 26 pages, 30 cars represented on each page. It's also curious that it adds 15hp to a 255hp Max and a 130hp Cirrus.
I guess car manufacturers all made the exact same "fuel/air ratio" mistake on 780 different model cars. Engineers are so dumb!
I would be surprised that this thing adds 1hp. When I had my TA i bought one of the air sensor module which was suppose to cheat your comp that the engine temp was cold at all times. The hp gain was 10 hp and i didnt feel a thing, this chip is waste of money and might mess with your engine I wouldnt buy it.
Spoof
I wonder if it is a resistor of some sort. Unless it is a system within itself it is only sending voltage as he said back to the ECU hence what is called a spoof. This simply does slow down the signal to the ECU but no HP increases, just may help you on not getting the ole CEL..
