Does anyone have a bolt on.....
Old Jul 17, 2002 | 03:19 PM
SportyMax2002's Avatar
I was just wondering if anyone has a bolt on exhaust or muffler? If so, how hard are they to install and do you think they are better than getting an exhaust to weld on. Also, where do I get them and how much do they usually run for? The reason I would like a bolt on is because it is a leased car, therefore, it would be easier to take off in the end. Thanks in advance guys.
Old Jul 17, 2002 | 03:23 PM
WILLSE's Avatar
Re: Does anyone have a bolt on.....
i have the HKS. it is good if u want the capability to change out ur exhuast. it is bad bc ur gasket can have small leaks blah blah. it is very hard to change the muffler out in ur drive way. it is a VERY funny angle and the muffler has to bend down very far. get an exhuast shop to put it on for 20 bucks. i did it in my driveway but i did it a very dangerous way.
will
Old Jul 17, 2002 | 03:26 PM
Dario's Avatar
a bolt on exhaust is one of the easiest mods to do, like my Stillen exhaust all you do is jack up the right rear and remove the tire. (easier this way) from this point u can access the bolts needed to take off the exhaust but dont forget to remove it from the rubber hangers under the car. and thats it
Old Jul 17, 2002 | 04:06 PM
Thanks.
Thanks guys, do you know if you can find them on the internet for cheaper or should I just look around town in the local shops? How much do they usually run for too? Thanks.
Old Jul 17, 2002 | 04:34 PM
Dario's Avatar
well the exhausts you weld on are usually around the 100-150 mark and the complete exhaust is around the 300-400 range depending on the company. just look around in performance shops if any in your area if not you can always try pepboys.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
