Sidemarker rewire: have hazards, no turn signals
Old Jul 23, 2002 | 02:26 PM
BJGemini's Avatar
I followed the 5thgenmaximas.com rewire instructions to the T!
I now have hazards that blink, but when i use my turn signal, nothing happens.
I made sure I used the Green wire from the turn signal, and connected it to the Black (ground) of the sidemarker.
Could this be a fuse? Or did I rewire incorrectly?
Brian
Old Jul 23, 2002 | 02:33 PM
BigDogJonx's Avatar
Did you CUT OFF the black wire on the sidemarker? or did you just tap the green wire from the turn signal into the black? If so that is your problem mate.
Dixit
Old Jul 23, 2002 | 02:41 PM
BJGemini's Avatar
Dixit
Nope - Cut the Black (ground) wire in half, used the half attached to the sidemarker to attach to the Green signal wire (via a NEW wire).
The other half of the Black (ground) wire that attaches to the car, is e-taped up doing nothing.
Brian
Old Jul 23, 2002 | 03:05 PM
BigDogJonx's Avatar
Then you burned out the turn signal fuse. Might have done during the crimping.
Dixit
Old Jul 23, 2002 | 04:26 PM
BJGemini's Avatar
Re: Sidemarker rewire: have hazards, no turn signals
Brian
Put your key in the ignition and then test them.
Brian
Old Jul 23, 2002 | 04:28 PM
BJGemini's Avatar
Re: Re: Sidemarker rewire: have hazards, no turn signals
Brian
Thanks,
They work now.
Brian
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
