Do Eibach Camber Bolts help?
Old Jul 27, 2002 | 12:34 PM
vman's Avatar
Does anyone know if Eibach Camber Bolts help to align the car better. Because I have 18's and I see a bit of negative camber so would this help adjust back the normal alignment
thanks
vilash
Old Jul 27, 2002 | 01:24 PM
Larry's Avatar
I have camber bolts in my 2002 Camry already. It had bad negative camber right off the dealers lot and they would not align it. I went to the auto parts and bought camber bolts, installed them myself and then had it aligned. I don't remember the brand but they sure do work for adjusting camber. They were less than $15 each(per wheel).
Old Jul 27, 2002 | 04:46 PM
Galo's Avatar
Maxima Pilot
Why do u want the negative camber out??
If it's reasonable (between .25 degree to .75 degree negative) its fine...will improve cornering as well as reduce torque steer with the only drawback being a bit more than normal bump steer.
Why do u think racing cars have such radical negative camber? Compensates for the outside front wheel rolling over onto its sidewall in a curve...
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
