buy a courtesy 2k fstb vs. the stillen
Old Dec 13, 2000 | 05:38 AM
Kenneth's Avatar
OG :)
thought i share an extra option... http://www.courtesyparts.com/
Old Dec 13, 2000 | 08:01 PM
MrBurner's Avatar
have you tried both? i know the courtesy is cheaper but not all fstb's are the same, they have different measurements...i know they will both fit, but if the stillen one is thicker and better, i'd rather go for that...has anyone tried both and can give an honest opinion on which is better...forgetting about the money
Old Dec 13, 2000 | 08:37 PM
jnm2kse's Avatar
With the new 2K
FTSB I know you don't have to cut that bracket piece that you used to have to...........do you still need to remove that little bolted on thing(lack of a better term or knowing what the hell it is ) on the passenger side(then put it back on. Looks like it would still be in the way if you left it on during install....
Also concerning install...seems pretty easy...just make sure you are on a flat surface, unbolt, put on, rebolt, bingo all done..that easy? What should the bolts be tourqued to and do you undo one side at a time or can both be unbolted at the same time?
Old Dec 13, 2000 | 08:41 PM
ZMEGOBY
The Stillen one does not need any cutting it mounts on perfectly. n/m
Old Dec 13, 2000 | 10:27 PM
y2kse's Avatar
For the substantial difference in price . . .
I bought the Courtesy FSTB and did a little cutting. There is absolutely no difference in functionality between the Courtesy FSTB and the Stillen FSTB.
Check out http://web2.airmail.net/scutchen/max_faq/stb/index.htm
Old Dec 13, 2000 | 10:54 PM
psing23's Avatar
courtesy finally has the 2000-2001 bars so no cutting is needed... the stillen bar looks awesome but i dont know if its worth the extra $100 or so... Im still facing this dilema for myself...
Old Dec 13, 2000 | 10:59 PM
Krystian's Avatar
A strut bar is a strut bar. The only difference is the look of it, and $100 dollars.
Old Dec 14, 2000 | 12:16 PM
Kenneth's Avatar
OG :)
yup that easy
bingo, both sides at once is fine. don't over-torque
Old Dec 14, 2000 | 12:17 PM
Kenneth's Avatar
OG :)
exactly. stillen for show, both provide go..
Old Dec 14, 2000 | 12:31 PM
MrBurner's Avatar
different width's of strut bars matter...a strut bar is not the same as the next...thats why people buy different brands...they provide a different amount of handling depending on the thickness
Old Dec 14, 2000 | 01:40 PM
THEKNITE's Avatar
COURTESY
JUST INSTALLED A COURTESY 2K1 BAR TODAY. DIDNT' WANNA SPEND MONEY ON LOOKS WHEN HARDLY FEW PEOPLE WILL SEE IT.
PEACE
Old Dec 14, 2000 | 08:45 PM
Gerry's Avatar
MrBurner, How can the thickness of a strut bar matter? The strut bar operates purely in tension. As the mass of the car tries to push the outer tire's tread inward under the car, the upper part of the strut is pushed outward. The tie to the opposite strut resists that and thus helps the outer tire maintain more square contact with the road. As long as the strut bar is strong enough to resist breaking in tension (and we'll assume it doesn't stretch) any bar should act the same. It is not like a sway bar which is under torsional twist and resists with a force proportional to diameter.
Old Dec 14, 2000 | 08:57 PM
exunaja's Avatar
Re: COURTESY
PEACE
Is the installatin a perfect fit? Do you have to remove or cut any part of the body to get the Courtesy's FSTB install?
Thank you
Old Dec 14, 2000 | 09:42 PM
Kenneth's Avatar
OG :)
Re: Re: COURTESY
[/I]
not for the 2k bar and like bill said the stillen also fits fine
Old Dec 14, 2000 | 10:03 PM
exunaja's Avatar
Re: Re: Re: COURTESY
not for the 2k bar and like bill said the stillen also fits fine [/I]
Thank you.
Old Dec 15, 2000 | 12:38 AM
MrBurner's Avatar
o yeah, i was thinking of sway bars...sorry about that
Old Dec 20, 2000 | 04:30 PM
kaleb's Avatar
Please provide information to back this up. You are providing an incorrect hypothesis.
Old Dec 20, 2000 | 08:11 PM
jnm2kse's Avatar
Hey Guys
I understand that you dont need to cut anything with the 2K bar but I was wondering if you still need to unbolt that extra piece over on the passenger side to make room for the bar (and then of course put it back on after the bar is installed)
To me less fiddling with bolts the better
Did I make sense explaining that?
maxima-junky
Nov 10, 2015 09:12 AM
Domf3
Sep 22, 2015 03:05 PM
14GmMax
Sep 19, 2015 11:32 PM
Stagnet04
Sep 14, 2015 11:28 PM
