OBD Code 0420 - HELP!
Old Aug 6, 2002 | 01:38 PM
JodyBerry's Avatar
Well, after 2 times of my code being zero, I finally got a valid code on my 2000 SE. It's 0420 and the description is, "Catalyst System Efficiency Below Threshold". So, what would that mean in laymans terms? Can I fix it? I really hate going to the dealer unless I have to.
Thanks a million,
Bill
Old Aug 6, 2002 | 01:40 PM
Max_Gator's Avatar
Re: OBD Code 0420 - HELP!
Thanks a million,
Bill
If you find out let me know too. I have the same one!
What exhaust mods do you have?
Old Aug 6, 2002 | 04:32 PM
Colonel's Avatar
Old Fuddy Duddy
Thanks a million,
Bill
I seem to recall a post sometime about the tolerances being to tight and it needs to be "reprogrammed" to loosen them up....Sorry, thats all I can give ya.
Old Aug 6, 2002 | 06:17 PM
adman's Avatar
Yeah, it is a "Catalyst" code dealing with your 02 sensors. Mine was because of a bad flex section. But, you could have a "regular" exhaust leak if you have changed anything underneath...ie Y-Pipe, Cat, Etc.
http://forums.maxima.org/showthread....hreadid=118330
Hope that helps...
ADMAN
Old Aug 6, 2002 | 06:35 PM
The New CLIMAX's Avatar
I also have the same problem, and my exhaust consist of a Stillen Y-pipe, and RT CAT. So does this code mean that my Y-pipe has a leak, my RT cat flows too much air, my O2 sensors are bad (if so which one), I am kinda lost on what needs to be done to correct this. Thanks
Old Aug 6, 2002 | 07:22 PM
JodyBerry's Avatar
Well, unlike most of you guys (and girls), my car is bone stock
So, I would have to guess it's what a few of you have said; catalyst, o2, or maybe just a whacked ECU.
Thanks for all the info and help. This gives me a little more ammo when I visit Mr. Service Manager!
BTW, here's some info I found for anyone else who may be having the 0420 code:
Make: NISSAN Model: MAXIMA Year: 2000
Service Bulletin Number: NTB00070A Bulletin Sequence Number: 199 Date of Bulletin: 03/01
NHTSA Item Number: 619999
Component: INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR
Summary:
SOME VEHICLES MAY EXHIBIT A MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0420 (THREE WAY CATALYST FUNCTION) STORED IN THE ECM. *TT
Thanks again everyone,
Bill
2000 SE (bone stock)
Old Aug 7, 2002 | 08:19 AM
neil's Avatar
had that on my 2k @ 34k, dealer reprogram the ECM.
neil
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
